RV.Net Open Roads Forum: Dinghy Towing: Fiat 500 for flat towing questions
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Fiat 500 for flat towing questions
Hemlockdj
Colorado Springs, CO
Posted: 05/11/21 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Good day everyone,
We recently picked up a Fiat 500 to flat tow behind our 23ft class C. Does anyone flat tow a Fiat? If so I have a few questions. It is already setup to flat tow, and was wondering:
A: Does the key need to be into keep the steering unlocked? It does not seem to lock when I pull the key out so I'm assuming not.
B: It came with a braking system, Blue Ox patriot. The previous owner plugged it into the 12v power plug and put the key in acc to power it. Does anyone use a separate power source like the ones for jump starting your car for the braking power?
Thanks in advance,
Dave
2017 23' Chateau
Cambria, California area
Posted: 05/11/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Suggest you follow the manufacturer’s instructions.
Y-Guy
Tri-Cities, WA
Posted: 05/11/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Dave, you want to check your owners manual, look for "Recreational Towing" to see what the steps are for flat towing your Fiat 500. Your vehicle should be flat tow-able (based on my past research), but the Fiat 500X is not. The additional 12v from the RV is a good idea so you don't drain you're battery.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
johnhicks
Wandering below the Gnat Line
Posted: 05/11/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Only the manual-transmission Fiat is flat-towable.
The key isn't needed for the steering.
The lighter/accessory outlet is switched by ACC. You could jumper the breaker to make it always live, run a new wire to an outlet or use an accessory battery pack. The Fiat forum folks appear to believe the jumpering the breaker won't blow up anything but no one's actually done it. I'll do that when I get around to installing the brake. I'm legal without braking but I intend to go with a RVI Brake. I have a Roadmaster air brake rig I used on the Tracker but it won' t work with the Fiat, and it's kind of an overall kludge anyway.
-jbh-
dodge guy
Bartlett IL
Posted: 05/11/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
If it were me I would run a dedicated outlet front he battery to power the brake system. And then run a charge wire from the RV to keep the battery charged.
The steering wheel does not lock with the key out.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
LadyRVer
Posted: 05/11/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I towed a Fiat 500, manual transmission, for 2 years. Did a dedicated power line for the Brake Buddy. Great little fun car. No key needed. Never had a dead battery.
johnhicks
Posted: 05/11/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Where did you run that line inside?
