doughere
Mooresville NC
I'm looking for a high current adjustable voltage charger in the 50 amp range. I know I can parallel a couple of 30's, but would rather a single unit.
BFL13
Victoria, BC
https://www.boatandrvaccessories.com/pro........-amp-12-volt-power-supply-with-led-light
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
doughere
Mooresville NC
Thanks
pulpwood007
Hemphill, TX
The PowerMax is an excellent value. I just installed a Progressive Dynamics 60 amp converter:
https://www.bestconverter.com/PD-9260C-60-Amp-RV-ConverterCharger_p_171.html
I like it because it has a remote control pendant that you can use to select the voltage. The PowerMax requires using a small screwdriver, which would be fine if not needed very often.
