RV.Net Open Roads Forum: Mounting Truck Camper on Top Of 5th Wheel Hitch Rails
 > Mounting Truck Camper on Top Of 5th Wheel Hitch Rails
vwsportbug
Ontario, Canada
Posted: 05/12/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a Truck Camper to use but don't want to remove my 5th Wheel Hitch rails from the truck bed. I would still like to use a 3/4" rubber bed mat under the camper but how do I get the clearance to get above the rails? I'm thinking of using 2 X 6 boards across the bed in front of, between, & behind the 5er rails to lift above the rails. Should I use a rubber bed mat below the 2 X 6 boards or on top of them? I'm sure I'll have to trim the rubber mat to fit around the 5er rails.
What have others done? Thanks in advance!
VeeDub
2006 Carriage Cameo LXI F35FD3
2006 Ford F350 Dually
Near DVNP, California
Posted: 05/12/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
How much higher will camper ride than if directly on the truck bed?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
NRALIFR
Truck Camping Out West
Posted: 05/12/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
The first dually pickup I owned came with fifth wheel hitch rails in the bed from the previous owner. It also came with a rubber mat in the bed with cutouts for the rails to poke through. I found that 5/4” treated deck boards were just the right height to allow the camper to clear the rails.
I attached them to the bottom of the camper, and also had the smart idea to place two of them so they landed directly in front of the hitch rails. They acted as guides for the camper when lowering it into the bed, and prevented it from moving backwards while traveling.
The first one is new because I had just replaced it. The first one developed a long split.
[emoticon][emoticon]
Slymer
Ontario, Canada
Posted: 05/12/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used numbered 2 x 4's to get above the rails. I then attached the last 4 together so I didn't lose one 2 x 4 going down the road. After I got the wood in I used a 3/8" horse stall mat so I didn't get too tall.
TxGearhead
Posted: 05/12/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Use enough wood to get good support. Plywood on top of that. Then the rubber mat on top.
Or....throw the rails away and install a gooseneck ball and get a Reese GooseBox pinbox.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
BFL13
Victoria, BC
Posted: 05/12/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Started with a camper and the full bed mat. Got a 5er, they cut the bed mat in half across between the wheel wells, and cut slots in each half for the rails. Still have a bit of rail height above mat.
Whenever have to carry 4 x 8 sheets in the truck, use three 8 ft 2x4s to clear the hitch rails
Then got another camper years later. Used the 2 x 4 boards under the camper same as when carrying 4x8 sheets. The camper hold downs keep it all in place. The back of the camper hangs down below the bed so no problem with boards coming out the back with no tail gate there.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MN Ben
Minnesota
Posted: 05/13/21 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I have the 5er rails in my F350. We transferred a Lance 1130 from Michigan to Minnesota on top of a frame of treated 2x4s flat and toenailed with screw. The camper ended up slipping back about 8" from the bumping down the freeway. The tiedowns were vertical so they did allow the camper to slide and the wood was slightly damp from a rain. I stopped a couple of times to readjust and retighten the tiedowns.
I purchased a rubber livestock mat and will be using it next weekend but I also plan to remove the 5er rails and reinstall them when we use the 5er again. There is only 5 bolts for each rail so it wont be to bad for meI did not like the camper sliding.
2006 F350 Dually PSD
2004 Lance 1130
2002 F250 7.3 PSD -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
ryoung
Oregon
Posted: 05/13/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I used the high density foam board that is used under concrete for insulation. Get a 4ft x 8ft sheet that is 2 inches thick, cut out for the rails, and lay it in the bed. Used the same sheet for many years.
ryoung
2018 Ram 3500 SRW Diesel
2019 Wolf Creek 840
BFL13
Victoria, BC
Posted: 05/13/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the boards slipped on the metal truck bed? I can see that happening. Especially with the corrugated bed, less surface area.
On mine with the mat, the boards don't slip with the camper on. Maybe try it with the mat before going to the trouble of removing the 5er rails. Re-installing the rails each time could be a hassle if they need to be aligned just right to get the hitch on, and there is wiggle room in the rail bolt holes.
MN Ben
Minnesota
Posted: 05/14/21 04:48am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, the treated 2x4 boards slid on the metal bed. They stayed in place against the bottom of the camper. The boards were only fastened to each other in a picture frame design.
I would rather have the camper as low as possible, but two ideas I like are the 5/4 decking (with maybe a rubber mat under or on top) or the high density styrofoam as I have 4 sheets laying around.
Lots of ideas for the OP. What do you think vwsportbug?
