RV.Net Open Roads Forum: ★ Signon on via Chrome (Workaround)
Search only in Forum Posting Help and Support
Open Roads Forum  >  Forum Posting Help and Support
 > ★ Signon on via Chrome (Workaround)
jconnally
Trussville, Al
Posted: 05/14/21 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I use Google Chrome as my browser and although I can view the forums fine I can't logon and post (I'm posting this via IE). Both IE and Safari browsers logon fine, just not Chrome. I've tried multiple workstations and have the same issue with authentication. I enter my username and password and it jumps back to the signon page.
MODERATOR'S NOTE: A Chrome, MS Edge, and Brave browser workaround has been posted in this thread until the issue is addressed on the Forum websites.
* This post was last edited 05/18/21 11:06am by an administrator/moderator *   View edit history
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 05/15/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
I always use Chrome as my default browser. I have no problems. I am posting this using Chrome.
It sounds like something is not configured correctly or something is messed up in your settings. Have you tried deleting Chrome, restarting your computer, then reinstalling?
2021 F-350 Platinum 4X4 PSD SRW 2016 Montana 3950FL (2) Honda EU2000i's
...and a few (twenty-some, but other than my wife, no one is counting) antique Allis Chalmers tractors
1492
Arlington, VA
Posted: 05/15/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Issue appear to be related to Chromium based browsers such as Chrome, Edge, Brave, etc. I've flagged the issue on Mods forums.
In the meantime, you'll have to use Firefox or Safari.
1492
Arlington, VA
Posted: 05/15/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Chromium browsers also not working to 'sign-in' to the forums on macOS.
MitchF150
Puyallup, WA
Posted: 05/15/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Might have to try the old IE 11 browser if you logged out of your session using Chrome.. I am using Chrome right now, but I never 'log out'.. I just close the browser when I'm done and open it when I want to see stuff..
Yes, IE 11 is out of support, but it should work with the out of date forum format too. [emoticon]
Good luck! Mitch
1492
Arlington, VA
Posted: 05/15/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, don't 'logout' if you're using Chrome. You will not be able to log back with the same Chromium browser.
1492
Arlington, VA
Posted: 05/15/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
I think I've discovered the 'Login' issue with Chrome. The forums are apparently using cross-site cookies, but missing a necessary attribute required for Chromium browsers. GS IT needs to update their websites.
I'll post a workaround in the meantime shortly.
1492
Arlington, VA
Posted: 05/15/21 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
If you cannot 'Log-in' to the Forums using Chrome browser, you can try this workaround:
    1. Copy and paste the following (bold) into Chrome's address bar and press ENTER:
    chrome://flags/#cookies-without-same-site-must-be-secure
    2. In 'Cookies without SameSite must be secure', click the Default button, and select Disabled.
    3.EXIT and re-start Chrome browser.
Try to 'Login' to the Forums.
1492
Arlington, VA
Posted: 05/16/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
This Chrome workaround also works in MS Edge and Brave browsers.
jconnally
Trussville, Al
Posted: 05/16/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the workaround. I applied and resolved the issue.
Joe
2008 Chevy 3500 SRW Duramax/Allison
2011 Sierra 345RET 38'10"
(2) Honda EU2000
