RV.Net Open Roads Forum: Yellowstone Next Week - Freezing Temps Concern
 > Yellowstone Next Week - Freezing Temps Concern
ajriding
st clair
Posted: 05/15/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Water freezes at 32, but where does affluent freeze?
For damage to be done your valves will need to freeze solid, and temps will need to be lower than 30 for a long time.
The solids will not expand like water when frozen, so that is good, but they contain high % of water still.
You will need some sort of tank heater (stick-on heating pads) if you do this a lot. You will need power though.
time2roll
Posted: 05/15/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
InTheRockies wrote:
Forecasted low temps look to be around 30-35. Am I worrying too much?
Yes. Most any RV is fine down to 25 while in use.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 05/15/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I would not worry until 27 F.
Regards, Don
agesilaus
North Florida
Posted: 05/15/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
According to my FIL who was a manager for the Dept Of Agriculture, rapid freezing occurs at 26 deg F. And that means in an hour or two for a water hose. But up in the thirties it is not an issue if the temps are above freezing during the day, most of the time. We had a water hose freeze a few weeks ago outside Bryce, was not watching the weather closely. No big problem, thawed out in a couple hours, no damage.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Bionic Man
Colorado
Posted: 05/15/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
I've spent many days below freezing in my trailer. Sounds like I have a bit more insulation than you have, but I wouldn't worry. The heat from the trailer will keep you from freezing. One piece of advice - have at least half a tank of water in your fresh tank. I have been there when the water spigot froze, and I didn't have enough water in my fresh tank to last the day.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
SpeakEasy
Western New York
Posted: 05/16/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
A couple weeks ago we experienced several nights below freezing in our travel trailer in Arizona and Utah. The coldest night was 24 degrees. Had absolutely no problems. The only thing I did to prevent problems was to remove the outside shower head from its hose and bring it inside. The valves for the outside shower were still vulnerable, but there wasn't much I could do for them other than keep the bathroom cabinet door open and the bathroom door open to allow warmer air to access the areas closest to the outside shower.
Temps around 30? Nothing to worry about.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
InTheRockies
Colorado
Posted: 05/16/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input. I’ll take the advice here and not worry about temps in the low 30s.
2019 Forest River Cherokee Grey Wolf 17BHSE
2006 Ram 1500 SLT Sport 5.7L Hemi, CC, 6.5' box
Posted: 05/16/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Another factor people forget
32 degrees F or 0 C is the freezing point of DISTILLED water at precisely one atmosphere pressure.. Different pressure will change the freezing (and boiling) points.
Impurities will also LOWER the freezing point (And generally raise the boiling point) That water in the black and gray tanks... VERY VERY Impure.
PatJ
Eastern WA
Posted: 05/17/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
I was worried my first few cold nights in my "new" (2019) rig as I do not have tank heaters or anything fancy like that. I have since spent many nights below 30 and two nights where I woke up to 20f and no issues so far. So far I have pictures in 5 states with snow all around my rig. I didn't try to flush tanks at 20f, but nothing broke dropping down there for a few hours late night/early morning and we used the rig normally. My drain/flush valves are what I was most concerned about.
Patrick
