RV.Net Open Roads Forum: Fifth-Wheels: Tripod for a new fifth wheel
 > Tripod for a new fifth wheel
Sagebrush
Jacksonville AL
Posted: 05/16/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I use the scissor jack things between the axles, seems to do the most good on my old trailers with basic manual stabilizers.
whiteeye42
Rock Springs Wyoming
Posted: 05/19/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
i had one and used it 3 times more or a pain to set up so i sold it and i also have a bipod that i got and used it twice
* This post was edited 05/19/21 05:50pm by an administrator/moderator *
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
B.O. Plenty
Minnesota
Posted: 05/19/21 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
I especially laugh when I see someone using it with an air ride hitch.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
time2roll
Posted: 05/19/21 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
You needed to get the decapod model to at least use it ten times [emoticon]
675w Solar pictures back up
allen8106
Burrton. KS
Posted: 05/20/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
CampinginCanada wrote:
What are your opinions of using a tripod on a new fifth wheel? I have ordered an Alliance Valor 41V15 that comes with a six point stabilizer system. Do you find that the tripod helps with trailer sway?
Cheers,
Fred
I don't recommend the tripod. If you want real stabilization install a set of JT Strongarms.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
JIMNLIN
Oklahoma
Posted: 05/20/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Cheers,
Fred
Common sense tell us a pin stabilizer was never meant to stop all trailer sway motions. Logic says it can help eliminate side to side sway in the front where the pin is.
For that I've used a aluminum bipod pin stabilizer since 1984 when I bought my 1st 5th wheel RV trailer. The trailer had no OEM leveling system.
Also logic tells us side to side sway at the rear of the trailer needs help. For that I use the BAL telescoping stabilizer. Some use other stabilizing products.
Logic now says fore and aft movement will need to be addressed. For that part I use a adjustable chocks. Others use some type of tire chalks.
Now I'm rock solid.
If you use another aftermarket jack or a screw type stabilizer don't forget to back them down first. Most aren't meant to carry weight but just stabilize movement.
ford truck guy
Pennsylvania
Posted: 05/20/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Had 1.... got tired of hearing it clumping around my bed, not being used.... gave it to someone on here...
Save your money
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Splashers3
Oakville, MD
Posted: 05/21/21 01:48am Link  |  Quote  |  Print  |  Notify Moderator
Our current 5ver has the 6 pt leveling system so we no longer need the tripod. However, our previous 5ver did not have 6 pt leveling. We used the tripod only when we were staying more than a weekend. It helped somewhat. On 2 night stays we generally didn't put it out.
It now sits in our house basement.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
danskool
Elma, N.Y.
Posted: 06/03/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I have two . Both were given to me. I tried for a while. They are a pain to use and I don't bother. Not worth their weight and space but they are worth scrap metal.
Dan
2021 5th Wheel Crusader 29RS
2001 F250 XLT 7.3 PSD
