RV.Net Open Roads Forum: An easier way to fill propane tanks on Lance 1172
 > An easier way to fill propane tanks on Lance 1172
woodworker414
Crystal City,Mo.
Posted: 05/16/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon everyone.
I knew when we bought the 1172 I would be looking for a way to fill the propane tanks.
Since the bottom of the tanks are about at shoulder height.
Getting older and having arthritic shoulders, I see a issue putting a 30# tank back into the compartment. The filled tan weights about 55#.
I have read where some folks have done things that will allow the tanks to stay in place and be refilled. I done a search and can not find any info. If I have to I may replace the tanks with a motorhome horizontal tank. Any and all thoughts and ideas appreciated.
Brenda and Bill
2020 Lance 1172, our traveling rig
2013 Heartland Landmark Mesa, 40', fifth wheel, we keep at our snowbird home in central FL, Bushnell, FL.
2014 Chevy Silverado LTZ 3500HD, CC, 4x4, LB, duals, DuraMax
SoonDockin
Oklahoma
Posted: 05/16/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I see this as a double edge sword. When my TC is off the truck and sitting low I can easily reach the tanks and stick them in the trunk of my car or back of my truck when out shopping and get them filled. I would think the tank would need to be low for most places to want to fill them.
It will be interesting to see what anyone has come up with. Maybe use the generator spot, its much lower.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
NRALIFR
Truck Camping Out West
Posted: 05/16/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Would carrying a step ladder be possible? I was having the same issue with my horizontal 30#’ers when I was recovering from shoulder injuries. I could get the empty one out ok, but getting a filled one back up on my shoulder so I could slide it in was........tough. And painful.
I started carrying a step ladder tall enough that I could handle the cylinders at about waist height.
[emoticon][emoticon]
SoonDockin
Oklahoma
Posted: 05/16/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I keep a step ladder in my precious storage just for that and if I need to get taller to cut limbs.
Geo*Boy
Unknown
Posted: 05/16/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a Louisville FS1504 4’ fiberglass step ladder which sits across the back seat of my truck.
fpoole
PNW and Beyond
Posted: 05/16/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I use a little step ladder and can take them out and usually whoever is filling will help you put it in..
Not sure what the Regs are on filling in place..
Seems they usually have long enough hoses so might be something else.
Just a thought.
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
Old-Biscuit
Verde Valley
Posted: 05/16/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Portable cylinders....haven't found a place yet that will refill with them still in place
1st off they should be filled Vertically
2nd they should be weighed when filling
3rd bleed valve should be cracked open when filling
Seems a step ladder is feasible....IF you are stable on one
US NAVY------USS Decatur DDG31
Kayteg1
California > Nevada
Posted: 05/16/21 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
I believe it is the same setup I have in Lance 1161.
The tank is 7.5 gallons so for summer trip it gave me about 6 weeks of use.
I removed the 2nd tank, what gave me nice storage for BBQ and snorkeling gear.
Just refill it every 4 weeks and be on your way.
jimh425
Western MT
Posted: 05/16/21 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
A step stool does make a huge difference to take a tank down.. On thing I do is use the outside tank first, and try to fill it before I run it out and turn the other tank off even though I have an automatic switchover. That probably means I fill up more often than I need to..
I’ve also found taking the tank off when it’s not loaded on the TC makes it easier. Some propane guys have no issues with filling them in place, so that’s something to consider. Maybe it’s against the rules, but some don’t seem to care. Probably worth seeing if they will either take it down for you or simply fill in place before you exert the effort. YMMV.
One time, I had a dislocated collarbone so DW asked the guy to take it off. He seemed to have no issues with it, and of course, DW thanked him. He was young and strong like most people who will fill them. [emoticon]
woodworker414
Crystal City,Mo.
Posted: 05/17/21 05:57am Link  |  Quote  |  Print  |  Notify Moderator
SoonDockin
Thank You for the reply
I have a 2 step ladder I will try, if I have to I will take the tc off the truck and refill the tanks.
With 60# of propane I would think that will last a long time.
Can't remember from when I owned a RealLite 1200 which had 60# of propane how long it last.
