RV.Net Open Roads Forum: RV Fresh Water System Sanitized Using Vinegar & Water Heater
 > RV Fresh Water System Sanitized Using Vinegar & Water Heater
Camper_Jeff_&_Kelli
Seattle
Posted: 05/17/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I'm starting a new thread on this topic. The previous thread was the suggestion of doing this. This thread is having done the vinegar and water heater cleaning sanitizing method.
Previous Thread:
I tried a new method to clean and sanitize my Truck Camper Fresh Water System. This is a safe method, no bleach. Bleach as you know is a powerful time proven method of cleaning and sanitizing. If you don't want nasty chemicals in your water system this is a good alternative. It's a little more expensive, time consuming, and requires some mechanical know how, but the result is very good. No nasty chemicals in your drinking water from bleaching. Also, Vinegar is food! It doesn't want to kill you. TC - RV People, Enjoy...
* This post was edited 05/17/21 09:27am by Camper_Jeff_&_Kelli *
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
BobsYourUncle
Calgary Alberta Canada
Posted: 05/17/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I opened your youtube link and it takes me to an ad for a local grocery store.....
No thank you. When I see an ad it gets closed immediately.
I like the concept and idea of what you are posting here. Good work![emoticon]
I don't like putting bleach in my fresh water. The smell lingers even after flushing the system.
I use vinegar to clean my Keurig coffee machine. Works good. No reason why not to use it in our RV water systems.
Thanks for posting this.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Camper_Jeff_&_Kelli
Seattle
Posted: 05/17/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I don't care for the several tanks lingering of bleach either.
Simple rules for watching videos, click to SKIP ADS and fast forward through boring parts.
Just click to skip the ads. Fast forward in the boring spots.
jdc1
Rescue, Ca
Posted: 05/17/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
While vinegar does kill some bacteria, it does not come close to what bleach does.
SoonDockin
Oklahoma
Posted: 05/17/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Link worked fine for me, no ad but thats my addblocker doing its work. Its a good concept, key is getting the water hot enough.
I might give it a try. Its supposed to be a good way to rid towels and clothes of moldy/musty smells. So far its kind of hit an miss for me.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
Camper_Jeff_&_Kelli
Seattle
Posted: 05/17/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
That's where the heat comes in. Even if the water temp doesn't make it to the 130 degree mark, The hot water and vinegar will still create a good cleaning action rinsing out the system removing some crud from inside surfaces and rinsing stuff out the drain pipe.
BobsYourUncle
Posted: 05/17/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I looked at your other thread where you describe the process.
Are you actually able to bring the overall temperature up to a decent amount by recycling it?
I have never done this, but with a small HWT with limited heating capacity, I would be inclined to think there would be too much temperature loss in the fresh tank and the lines to be able to bring the whole thing past lukewarm.
Just wondering....
Camper_Jeff_&_Kelli
Seattle
Posted: 05/17/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering....
It took a couple hours but the TC water heater did get the water hot enough that you didn't want to hold your hands in it. The water heater did shut off when it reached temperature. I kept the pump running until the water heater cycled again and I considered it mission accomplished. I think the fresh tank doesn't lose as much heat as people may think. It's a big volume with a small surface area. The bottom and front side have 1/2 inch Styrofoam insulating. That is nearly half the fresh tank surface area is insulated. So the main heat loss is from the fill hose and the other half of the fresh tank. It's kind of like an elephant versus a rabbit for heat retention. Take care...
specta
utah
Posted: 05/17/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use bleach. It attacks the DNA of the germs. That's why germs have not become immune to it and its been around for 200 years.
I put it in my FW tank and run it thru everything.
Then I drain the FW tank and the water heater. I don't let it sit in there for ever.
I refill them with FW and run it through everything again and drain everything again.
I've never had the smell of chlorine linger after thoroughly flushing system.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
rlw999
Washington State
Posted: 05/17/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I use Purogene sanitizer with citric acid for once-a-season sanitizing. After that, since I usually refill with filtered, unchlorinated well water, I add a small amount of Purogene (1 oz per 30gal water) with every tank refill to keep the water clean (the water may sit in the tank for weeks between uses).
I rinse and drain the tank once after sanitizing and it doesn't leave any strong chlorine taste/smell behind, but I don't normally drink out of the freshwater tank.
It's the same chemical airlines use for sanitizing airplane water tanks.
* This post was edited 05/17/21 07:49pm by rlw999 *
