RV.Net Open Roads Forum: Travel Trailers: Want your opinion
 > Want your opinion
colliehauler
Mc Pherson KS USA
Posted: 05/19/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
wanderingaimlessly wrote:
IF you own the lot, and know you will not be towing the trailer, have you considered a small house?
From log to trailer type units many possibilities, more solid construction in many cases, and can have an empty interior to build out as you wish.
Some are made on skids which can be dropped off onsite, others are on trailers.
One site, by no means a recommendation, but may give you some ideas.
tiny house
I don't own the lot but have been there 15 years. For zoning it has to be a RV.
Sandia Man
Rio Rancho, NM
Posted: 05/19/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Being frugal ourselves the obvious choice for us is repair what you have. The only reason to have an RV is to be mobile, a prefab unit is cheaper and better constructed for the long haul, there are plenty of used and repossessed units on the market where they include delivery and set-up.
We have a ranch that we are looking to do the same, we have 33' TT toyhauler there currently but it doesn't cut the mustard for truly comfortable long term stays, will be used as extra sleeping quarters and storage for ATVs/UTVs once we get prefab delivered.
Whether now or in the past, with very few exceptions, RVs are constructed as fast as they can push them out the door, pandemic hasn't changed much in that respect. Plenty of new RVs on the lots in ABQ area, although I prefer buying gently used, last July found a creampuff class A.
colliehauler
Mc Pherson KS USA
Posted: 05/19/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 5th wheel TH for travel. The seasonal has to be a RV for zoning. My current seasonal is 35' with 7' ceilings and feels like a small home. Not against buying used but want the same floor plan I currently have.
Krusty
Calgary, Alberta,Canada
Posted: 05/19/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I am in the same situation. I have an older trailer on a seasonal lot. The trailer is getting old and starting to need a bit of work, but it is still in good shape and still does its job well. I don't see myself replacing it for awhile.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
QCMan
Independent Republic of Horry
Posted: 05/19/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Have you given any consideration to a used park model?
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
colliehauler
Mc Pherson KS USA
Posted: 05/19/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I have, but the used prices for what I want are to close to new price. I'm looking at a Ceder Creek Cottage 40 CRS.
bgum
South Louisiana
Posted: 05/19/21 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Don't understand statement about 220 vs 120. Did you mean 50 vs 30 amp. Since they are all 110 in US.
deltabravo
Spokane, WA
Posted: 05/19/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
colliehauler wrote:
This trailer sits on a seasonal lot and won't be towed.
For that kind of usage, I'd fix it and keep it.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 05/20/21 12:21am Link  |  Quote  |  Print  |  Notify Moderator
I'd rehab what you have if you like the floorplan. Removing windows and replacing the butyl tape is very messy but fairly simple work.
Our motorhome had 15 year old appliances but they all still worked just fine despite looking a bit dated.
We did upgrade the built-in TV with a LED model, but other than that, if it ain't broke, leave it alone.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
valhalla360
No paticular place.
Posted: 05/20/21 04:53am Link  |  Quote  |  Print  |  Notify Moderator
I'm hearing two conflicting thoughts reading between the lines:
- You want to make the best financial choice...in which case repair and upgrade will win easily.
- You are trying to justify the fancy new unit...in which case, if you can afford it, just do it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > Want your opinion
