RV.Net Open Roads Forum: Truck Campers: Truck bed camper shim
 > Truck bed camper shim
Supercharged111
Colorado Springs, CO
Posted: 05/20/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
My Lance has always say ass down in the bed. I'm wondering what you guys have done for shims? I had an old piece of plywood lying around and cut about a 42x48" piece and put it in the back half of my bed. I used my planer to taper the leading edge. I'm wondering if I should have cut it shorter? The camper is about dead nuts level now.
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
jimh406
Western MT
Posted: 05/20/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I just use air bags to level the camper/truck.
monkey44
Cape Cod, MA and Central Fla
Posted: 05/20/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Photo before and after might help.
Is the truck level and the camper not???
My HD sits low in front when unloaded, and level when camper loaded.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
Supercharged111
Posted: 05/20/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Truck is level, camper is not. I'll have to look up posting pics, but the 42" piece has made an improvement. I just wonder if it's too long and the camper may teeter on it?
mellow
Salisbury, MD
Posted: 05/20/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
1131 is a long camper like my 1191 and hangs off the back quite a bit. Is it possible that you have rot in it making the back sag that hangs off?
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Supercharged111
Posted: 05/20/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Rot on the camper or truck? Truck has none, camper is unlikely to have rot being from CO but anything's possible.
Slymer
Ontario, Canada
Posted: 05/20/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Ours always looked tilted too & it made no sense. Finally figured out something. Take a 5 ft board & put it across both bedrails, just behind the back window. Now take a measurement from the bottom of that board to the truck bed. Now take that board and move it back just forward of the tailgate & take that measurement again. On our 2011 F350 there was almost an inch difference if I remember rightly. Basically a manufactured optical illusion. No idea why, so I just got used to it.
cooldavidt
Vancouver
Posted: 05/20/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
It is not a good practise to support only part of the TC bottom on the truck box floor.
When you do part of the floor is unsupported and could sag and could develop weakness and cracks.
I use a slab of closed cell construction foam. 100% coverage. 4x8 in my case. Easy to cut if need be.
Cheap and waterproof.
352
Oxfofd, Fl
Posted: 05/20/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Have the old lady move to one side or the other to level it out.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
MORSNOW
Mountain Home, ID
Posted: 05/21/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
GM truck boxes are not flat, they have a peak across the bed by the wheel wells to allow water to drain from the front and rear of the box. Campers will rock on this peak unless a shim is placed in the rear. I used two semi truck mud flaps under my rubber mat to make a level surface. Use a straight edge, like a 4' level and slide it on the floor of the box from front/rear and you will see the peak.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
