RV.Net Open Roads Forum: Tow Vehicles: Ford Superduty Death Wobble fix
Search only in Tow Vehicles
 > Ford Superduty Death Wobble fix
agesilaus
North Florida
Posted: 05/20/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
I know this has been discussed before. But I am seeing increasing signs of the DW in our 2012 F350 6.7L 4WD. I see that dual steering dampers is being put forward as a cure. I have a Bilstein single damper but it is over 5 years old.
So has anyone out there tried the dual dampers, did it work and which system did you use? Thanks.
Lastly do my 5+ year old Bilstein front shocks need replacement too?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Fisherman
Angus, Ontario, Canada
Posted: 05/20/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the upper and lower ball joints, they were the culprits in my 3/4 RAM. Death wobble scared the heck out of me at 60 mph. Took truck to the dealer, they said the ball joints were within spec, went to a Napa garage and the guy wouldn't let me drive home, the left upper almost fell apart it was so worn out.
EYEMLOST
See Above
Posted: 05/20/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Death wobble is a result of worn out/broken parts.
Steering dampers only hide the problem.
Check:
Ball joints
Wheel bears
The ENTIRE steering set up/system.
Tire balance
Lug nuts
The ENTIRE suspension set up.
Death wobble can be any combo of the above, so you must check them all.
1998 FWC Grandby
1994 Ford Bronco 5.0 XL 4X4
Sky's ORD 6" Lift / Sterling 10.25 Dually 5.13 Gear Detroit Locker / '99.5 Front F-350 Leaf Springs at Rear / HMMWVtires
EYEMLOST
See Above
Posted: 05/20/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a big fan of Bilsteins.
Bilsteins are good for at least 100,000 miles.
agesilaus
North Florida
Posted: 05/20/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have a good mechanic finally I'm going to take it in and let them to give the suspension a careful check at the beginning of June.
theoldwizard1
SE MI
Posted: 05/20/21 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Check:
Ball joints
Wheel bears
Tire balance
Lug nuts
Concur!
All components need to be perfect l
4x4ord
Alberta
Posted: 05/20/21 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
My 2017 had the DW issue. I took it in at about 45000 miles and Ford replaced the steering dampener under some kind of extended warranty. It would get shaking quite severely. I tried speeding up ..... letting go of the steering wheel or jabbing the brakes ..... seemed like the only way to get it to quit was to come to just about a complete stop. Anyway after the dampener was changed it handled nice.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
C Schomer
Pueblo West, Co.
Posted: 05/23/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
"Death wobble is a result of worn out/broken parts." Not true! Everything in my front end is new and I just had it aligned and tires balanced. 200 miles later, I got my first DW Friday when I hit a pothole. Craig
EYEMLOST
See Above
Posted: 05/23/21 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Some points:
1) What is YOUR definition of death wobble, then?
2) You say, "Not true!"
Please back up that claim so we all can learn.
Your point tells us nothing that re-enforces your claim.
I smell a huge assumption on your part.
3) Is literally EVERYTHING that affects your front suspension and steering system new?
IS THE RIG NEW???
* This post was edited 05/23/21 12:03pm by EYEMLOST *
FishOnOne
The Great State of Texas
Posted: 05/23/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
EYEMLOST wrote:
Some points:
IS THE RIG NEW???
My 2012 Super Duty has 213,000 miles on it and it still has all original suspension parts except for shocks. My truck experienced the DW scenario twice in close proximity around the ~80k mile mark when I was running BF Goodrich AT tires when they were about at the end of life. Once I changed out those tires to a different brand it hasn't happened since.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
