2chiefsRus
USA Somewhere
2007 Knight - original owners with original microwave. Finally had problems with the Sharp convection microwave this morning. The push button to open the door no longer works. Luckily I was preheating it so there is no food stuck inside. Anyone have any insight into how to get the door open? Do we need to take the microwave down to get at the broken spring or latch? Thank you for any assistance you can offer.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
DarkSkySeeker
Freestone, California
You were running it empty?
There is something special about camping in an RV.
DrewE
Vermont
Probably you'd need to take it down, if you can't see anything else obvious.
Be aware of the electrical hazards of mucking about in microwave ovens. Even with the unit unplugged, there's the potential for a lethal charge to be stored in the capacitor for a long time. Usually they have a bleeder resistor to discharge the capacitor when it's not in use, but if it failed the oven generally would still work fine and you'd be none the wiser. Microwave ovens are said to be about the most electrically dangerous common home appliance to work on...which is not to say it cannot be done safely by ordinary people, just that one needs to take care and be wise.
dodge guy
Bartlett IL
Microwaves are cheap now. best to just replace it with newer and more efficient unit.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
ArchHoagland
Clovis, CA, USA
DarkSkySeeker wrote: >> preheating it so there is no food stuck inside
It's a convection oven so it can be preheated.
I took mine down to repair a problem...you need two people to remove it as it is very heavy and bulky.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
MountainAir05
New Mexico
first see if you can find a part. You have gotten your money worth out of it. To get to the latch you will have to remove the control panel and you will see your issue.
jdc1
Rescue, Ca
PartsWarehouse.com
2chiefsRus
USA Somewhere
You were running it empty? It is a convection microwave, I had it running on the preheat setting.
ksg5000
Oregon
The cost of new unit maybe less than repair - make a phone call to repair shop to determine.
Kevin
grldst
Dallas, GA
Easy fix and a heck of a lot cheaper then buying a new one. I replaced mine some yrs back, don't remember the exact procedure, but I do remember I did NOT have to remove the microwave, and it was not difficult.
My foggy mind seems to recall that you remove the facial plate around the door and you will get access to the bolts/screws to remove the door.
You should be able to google for parts, and you tube may even have a video on the repair.
ON EDIT: My memory has recollected that when the facial is removed you will see the door latch workings. The door does not have to be removed. Its a cheap plastic latch that breaks. I tried glueing it and it didn't last long, so I just replaced it. Like I stated earlier, the parts are cheap, the fix easy.
