RV.Net Open Roads Forum: Travel Trailers: Insect prevention in black tank
 > Insect prevention in black tank
Fstmvrerik
Salina, Ks.
Posted: 05/21/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
My wife and I are currently living in my Keystone Outback in central Florida awaiting our house to be completed. We are living in it full time. I travel for work, so when I am gone I leave the front (shower) and rear kitchen) grey water tanks valves open. the black water tank is closed, as she will not even hit 2/3 of a tank in the week. I dump and flush them on the weekend I am at home. We use orange black tank enzyme packs.
My wife is advising there are gnats that live in the black tank, and sometimes fly out of the tube going to the black tank when she flushes the toilet. She does hold the pedal down for a bit to ensure enough water to keep the poop pyramid problem from happening.
I have not seen the bugs yet, but am wondering if she could add some sort of insecticide to kill any insect life in the black tank: but not turn the tank into a bomb or damage it.
The upper ball seal in our Domatec 310 is leaking a little and the bowl will dry out over night. I plan on replacing the seal this weekend.
I do have a "dip" in my dump hose that holds water to make a P trap for the shower grey tank and kitchen to keep sewer gas at bay from the park sewer line.
Has anybody addressed this issue? Thanks for any assistance.
HappyKayakers
Somewhere in the USA
Posted: 05/21/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Google 'drain flies' for lots of suggestions. In the interim, I would fill the toilet bowl about half full before flushing to limit the time the valve is open.
You may not have to replace that seal. The last time this happened to me, I opted to replace also but could have gotten by with brushing the old, dried out plumber's grease from the original seal, applying new grease and reassembling.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
Monterey, California
Posted: 05/21/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Fill the black tank completely...completely...with chemicals, shake it up by driving and drain..twice...three times is better.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Sjm9911
New Jersey
Posted: 05/21/21 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have not had this issue on a camper. But yea, there sewer flys. Caused by having an open sewer drain. So, in a normal home, there would be an open drain or no water in a trap for that to happen. I would rethink leaving the drains open or make sure there was a water trap.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
time2roll
Posted: 05/21/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure how much but I would close the drain and pour some bleach down the toilet for overnight.
Maybe a whole gallon but I am crazy like that. Rinse well the next day. Only open the drain every few days as needed.
Good luck
675w Solar pictures back up
deltabravo
Spokane, WA
Posted: 05/21/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen people take their sewer hose that goes from the RV tank dump to the sewer line connection at the RV park and build a "p-trap" in it. THe will keep stuff from coming up the hose, but won't cure the problem of bugs currently living in the tank
mobeewan
Hampton, Va
Posted: 05/21/21 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
how to remove rv sewer flies & gnats
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 05/27/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Sheesh, all these people dumping bleach and chemicals in the tanks... you do realize that all has to go to a water treatment plant eventually, right?
I've never used chemicals. Straight water has always done the trick for us. Never had sewer flies but we never leave valves open, not even the grey.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
ronbiel
AL
Posted: 06/10/21 02:03am Link  |  Quote  |  Print  |  Notify Moderator
You can use Pool Shock. Just be careful when using it because it can bleach almost anything.
mobeewan
Hampton, Va
Posted: 06/10/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
So, instead of complaining about people using bleach and chemicals to kill bugs in their black tank do you have any constructive suggestions on how they get rid of them?
