RV.Net Open Roads Forum: Truck Campers: DC to DC converter for small electronics
 > DC to DC converter for small electronics
theoldwizard1
SE MI
Posted: 05/22/21 05:39am Link  |  Quote  |  Print  |  Notify Moderator
JoeChiOhki wrote:
So, something I also found during my searching, which might be a viable solution is Pico makes a small DC-DC Converter for UPS type functionality.
https://www.mini-box.com/picoUPS-100-12V........C-micro-UPS-system-battery-backup-system
Requires 15V - 18V input.
adamis
Northern California
Posted: 05/22/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
I am on my phone so couldn't read through the entire thread and don't know if this has been mentioned but you are looking for something like this I think.
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
FWC
The Wilderness
Posted: 05/22/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
FWC wrote:
This will do what you want:
Victron DC-DC Converter
Output range 10V - 15V.
Do the "double conversion" (DC - AC - DC). Safer !
The converter is adjustable over that range. It will regulate the output to better than 0.2V of the setpoint with less than 0.002V of noise.
This will work well for this application.
JoeChiOhki
Sauvie Island, OR
Posted: 05/22/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Camper_Jeff_&_Kelli wrote:
Hey Matt, So I take it you're trying to eliminate a 120 volt wall cord and go straight into the 12 volt connector using the 12 volt system of the house which will be 14.4 or 14.6 at times. 13.7 or 13.2 at others. and 12.8, 12.6 and going lower as the evening progresses until the engine or generator start charging. Sounds like the Victron may be the solution you're looking for. Since this NAS is going to be rattling around in the truck camper, are you going to be using SSD drives? Will your NAS accept smaller 2.5 drives? I have a couple LACIE 4T USB drives RAID capable if desired. It's a much simpler solution than a hardwired NAS unit in the TC and easier to take with you if needed. Probably not as capable though as a true NAS designed to serve several work stations but will easily work for one person/computer. I saw the RV GEEKS on YouTube the other night, released a video on their electronic communication and NAS system. They had a NAS with I recall 6 full sized bays but I don't recall if they plugged into 120 volt or adapted to use 12 volt. They have a huge LION battery system so I suspect they used 120 volt and let the unit make it's own clean power. Hope it works out whatever you end up with.
The nas in question is a small low power single drive qnap unit, it will easily use any 2.5 or 3.5 inch sata drive (it currently has a 6tb wd red pro nas drive in it, that will be getting swapped out for an intel ssd).
Its primary purpose is to act as the house plex server (do it yourself netflix), that we'll be syncing what we want for a trip from the big plex server at the house.
Its not really used for anything, I bought it for a short term project a few years back and its been collecting dust ever since.
So, I'm combining it with the campers network extender as part of the Amerigos systems.
* This post was edited 05/22/21 11:01am by JoeChiOhki *
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
JoeChiOhki
Sauvie Island, OR
Posted: 05/22/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Its definitely close and another idead to look for as I know some old laptops had 12v power supplies
mbloof
Beaverton, OR
Posted: 05/22/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
A quick peek at Amazon lists dozens of step up/down converters with 12V output.
https://www.amazon.com/KNACRO-Regulator-Automatic-Converter-Waterproof/dp/B08TSZG8RC/ref=sr_1_17?dchild=1&keywords=DC-DC+step+up+and+down+12v&qid=1621719998&sr=8-17
Simply pick and order one.
- Mark0.
Camper_Jeff_&_Kelli
Seattle
Posted: 05/22/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Would not this be much simpler LACIE USB-C 3.1 5T $170.00
I have a couple of these and they work very well. Lots of storage, fast, cheap, ruggedized. Plays video to your laptop nicely. There is a Thunderbolt version. They also have SSD versions but the price may be unnecessarily scary. Best of all, it's portable, take it with you and use it where you need it. Just presenting ideas for you.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
JoeChiOhki
Sauvie Island, OR
Posted: 05/24/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, that's just a basic hard drive, I have many of those already [emoticon].
We're setting up a mini-netflix, because more than one person can stream from it simultaneously (We have this at home with around 30TB in the current drive farm, I'm just miniaturizing it for a travel version with hardware I already own) using any number of devices (My wife likes to stream from her tablet).
In my case, I usually watch with our Roku on the TV, while dawn watches a different show on her tablet or her phone.
I am leaning at this point toward using this unit with the inverter vs the direct DC power, and instead use the DC to DC converter for the network extender, as it uses a lower voltage on its input than the nas does.
Bedlam
PNW
Posted: 05/25/21 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
JoeChiOhki wrote:
Bedlam wrote:
DC to DC conversion typically uses pulse width modulation with a feed back loop to keep the voltage regulated at a set reference under varying loads. The power is pretty dirty until filtered through some capacitors. It used to be easy to pick up all these components and scale it to your needs, but stores and user knowledge have been dieing out.
Yeah, finding any kind of small components is getting troublesome. I couldn't even find the same single pole 12 volt illuminated switches I had bought less than ten years ago (I ended up cannibalizing the originals out of Mr. KIT because I couldn't find anything nowadays half as decent a quality).
DigiKey and Mouser are still around for parts.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Camper_Jeff_&_Kelli
Seattle
Posted: 05/26/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Matt, Check this video out for fun. This guy is a technical wiz and created a NAS system from parts he had. He has a 5 volt power supply for his setup and a Raspberry PI is the controller. IT may or may not be useful to you but it is interesting to see what can be done if you have the knowledge. Hope you have your setup figured out by now. Looking forward to a full report upon completion and implementation...
