RV.Net Open Roads Forum: Tech Issues: Adjusting self adjusting brakes
 > Adjusting self adjusting brakes
Busdriver
Shepherdsville Ky 40165
Posted: 05/22/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Trying to adjust my self adjusting brakes can’t find the star wheel through the hole, any idea
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
HappyKayakers
Somewhere in the USA
Posted: 05/22/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Maybe they put it on backwards at the factory. The only reason I'm suggesting this is because I just did some work on my wheels (replacing lugs) and while I was pounding in the lugs I accidentally clipped the emergency brakes. A spring and the self adjuster fell off. When I put those parts back on, the self adjuster was backwards and I had to reinstall the next day.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
enblethen
Moses Lake, WA
Posted: 05/22/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Some do not have the star wheel. Opening but no manual adjustment.
Are you working on trailer or truck?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 05/22/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
There definitely needs to be a star wheel or they can't auto-adjust. There should be two slots at the bottom of the backing plate. The star is behind the slot closest to the rear of the trailer and toward the read of the slot. This is a right (Passenger) side photo.
[image]Click For Full-Size Image.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Posted: 05/22/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Dexter never adjust has no manual adjustment.
A1B00902
Vancouver B.C CANADA
Posted: 05/22/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Used to in the old days, backup quickly and hit the brake hard,
Posted: 05/22/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Sure looks like there’s still a star wheel on never adjusts. But idk
2017 Heartland Torque T29
Old-Biscuit
Verde Valley
Posted: 05/22/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer self adjusting brakes do so when going/braking forward
As for Dexter Never Adjust......YES they can be manually adjusted
The Dexter Nev-R-Adjust electric trailer brakes can be manually adjusted. There are a couple teeth of the adjustment wheel that are exposed just under the lever
Attached is a photo showing the teeth. You will likely need a tool with a fine edge such as a flat head screw driver for the adjustment wheel on these brakes. A brake adjustment tool may be too thick.
US NAVY------USS Decatur DDG31
Posted: 05/22/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have. on occasion. had to pull the drum to find the Q@!#$!@#$ Star wheel.
enblethen
Moses Lake, WA
Posted: 05/22/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't heard back from OP, whether talking truck or trailer.
