RV.Net Open Roads Forum: Fifth-Wheels: House battery not charging
 > House battery not charging
MPI_Mallard
Morpeth Ontario,St. Cloud Florida
Posted: 05/22/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Cedar Creek 36CKTS fiver' that I now see that the one 12V house battery seems not to be charging, as our fiver' is stationary and plugged in 24/7 while at our campsite I am at a loss as to why. If someone has any ideas also the proper way to diagnose it would be appreciated,,,
Thanks in advance
Red Green: Golfing is those who refuse to learn how to
fish!!
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
memtb
Wyoming
Posted: 05/27/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
A good place to start would be to thoroughly clean the battery terminal posts and cable clamps. You may also do a voltage measurement on the cables when disconnected from the offending battery to make certain that you are getting power to the cable clamps. Once certain that you are getting power to the battery......check the battery. The battery may be bad and “not” accepting a charge! If the battery is bad, and the pair are a year or more old.....I recommend changing “both” batteries. With both batteries the same age, you get a better charge balance with the batteries! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
time2roll
Posted: 05/27/21 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a battery switch inside? Need to select ON or IN USE.
675w Solar pictures back up
djousma
SW Michigan
Posted: 05/27/21 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
100% this is the problem. If it's the "Red Key" battery disconnect, a lot of times found in the front pass through compartment, if the key can be removed, your battery is disconnected. Turn the key. The wording on the switch is confusing.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
memtb
Wyoming
Posted: 05/27/21 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! Did I misread the OP! I thought that one of the 2 or more batteries was not charging. Am I to believe this unit has “only” one battery!
“If” the unit only has one battery.....I agree, the battery switch is likely the problem!
Or.....if is like our 5th wheel, it may have a “resettable” breaker that may have tripped. This happened to us in April. I do not know why we got the trip.....but it prevented the batteries from being charged by the solar panels or the tow vehicle! memtb
* This post was edited 05/28/21 08:56am by memtb *
