RV.Net Open Roads Forum: Fifth-Wheels: intermittent brakes
 > intermittent brakes
Page of 6
azbohunter
arizona
Posted: 05/22/21 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I am having the intermittent brake problem. I have done some diagnostics as recommended in other posts. I pulled the emergency connection and all four wheel rolled, I checked for power at wires coming out of that connector and had power, crawled under trailer on drivers side and checked for power at front axle, good. Checked rear axle and it was no go, wiggled some wires, pulled on wire going through axle etc, checked power and at rear axle drivers side again and it was there. Went back to truck, plugged emergency connector back in, checked dash brake with manual slide controller and it went up to 10, pulled the emergencey plug and all four wheel slide? So I have determined that the problem is wiring and not magnets or in the hub..but don't know where to go from here?
2006 Dodge Quad Cab Cummins 5.9 Automatic 4x4
2002 28RKD Lakota fifth wheel
Pullrite Hitch
2006 Polaris Ranger
16'Lund w/50HP Merc tiller
A great wife who loves to travel and fish
I love to archery hunt/she joins me and cooks!
Roger10378
Goodrich, MI.
Posted: 05/22/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
The easiest way is to run new wire from the known good point to all the brakes. Just make sure you use large enough wire.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
JRscooby
Indepmo
Posted: 05/22/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Disconnect from TV, and wire between battery (+) and breakaway switch. Using jumper wire, put a light in that wire, so it grounds thru brakes. Watch light while you shake wires. When it flickers/or goes out the bad connection is in your hand
azbohunter
arizona
Posted: 05/22/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to you both, sound advise. I will try the light bulb thing and see where that goes but seeing how my rig is pushing 20 years, I might just start at main wires and run new through axles and hopefully be covered.
* This post was edited 05/22/21 06:29pm by azbohunter *
Mike134
Elgin, IL
Posted: 05/22/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Replace all the splices, wiring never fails in the middle, always at the connections.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Near DVNP, California
Posted: 05/22/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
X2, Mike!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
azbohunter
arizona
Posted: 05/22/21 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have checked everything visible and I can't see anything that looks like it would be a problem. I have heard of insulation wearing off inside the axles over time. It might not be my problem but I think that I will pull new wires thru and then I will know.
Mike134
Elgin, IL
Posted: 05/22/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing the wiring will give you peace of mind that the wires are are good and you'll need to replace all the connections for the new wires so in the end your problem will be fixed.
safe travels.
Sjm9911
New Jersey
Posted: 05/23/21 04:53am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem on mine, except it only happened when i was going down the road. After a week or so of looking for it i replaced the all the wiring. That worked. And was much easier then chasing the problem around. I was getting a low voltage signal intermittently when towing.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Roger10378
Goodrich, MI.
Posted: 05/23/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Don't try to feed new wire thru the axle. Just run it on the outside and use zip ties to hold it in place.
Page of 6
