RV.Net Open Roads Forum: Tech Issues: Satellite Pre-Wiring
 > Satellite Pre-Wiring
LouLawrence
Traveling the US!
Posted: 06/25/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you installed a dome and not a Trav'ler. What was your final setup?
CarnationSailor
Carnation,WA
Posted: 09/09/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I did not install a dome or a Trav'ler. I had a dealer install an RF Mogul Eagle which is very similar to a Trav'ler.
IT worked great immediately after installation, but I had problems "acquiring a signal" the first time I moved to another location. Many support calls to Dish before finally getting a tech that identified the problem. The problem was the pre-wired coax that was used to connect the antenna controller to the receiver.
Instead of trying to get the bad coax replaced which would have been difficult and expensive, I ran a coax inside the trailer from the cabinet at the rear of the trailer where the controller box was located to the slide out with the entertainment center and Dish receiver. The cabinet and the entertainment center are only about 4 feet apart so I was able to do a neat run of the coax, and I left a loop of extra length that allows the slide out to move in and out without stressing the coax.
So far, so good.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
CA Traveler
The Western States
Posted: 09/09/21 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
HD and multiple channel reception (My DTV records 5) require better coax and connectors - ie less loss and higher bandwidth. This is for better reliability. If by dealer you mean RV dealer then I'm not suprised.
I'm curious: Was the prewire adequate for the power wires to the dish?
2014 Grand Cherokee Overland
Bob
CarnationSailor
Carnation,WA
Posted: 09/09/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
The installation was done by a Dish Network dealer that was an authorized installer of the RF Mogul antenna. He ran a new coax from the antenna thru the roof to the controller inside the rear/upper cabinet. He also connected the antenna to the controller with the multi-wire cable that provides power and control signals to the antenna.
To get the satellite signal from the controller to the receiver, he ran a new coax back up thru the roof to a pre-wired coax jack whos associated coax cable ran to the entertainment center where the receiver was located. (With the RF Mogul system, the satellite signal passes thru the controller to the receiver.)
He initially detected that the pre-wired jack was seriously corroded so he replaced it. When he checked out the installation, the system worked fine. (I don't know that he actually measured the quality of the signal going to the receiver. The system worked so apparently all was good.)
However, the problems I experienced where sometimes the receiver could acquire the signal and sometimes it couldn't, eventually lead to my running a new coax directly from the controller to the receiver (bypassing the pre-wired coax), and the problem went away.
