RV.Net Open Roads Forum: General RVing Issues: Need a new TV antenna
 > Need a new TV antenna
TurnThePage
North ID
Posted: 05/23/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
The old Winegard Sensar went walkabout during the drive home. Doesn't appear to be any damage except for the end of cable. The two square rods are still there, just no antenna. Looking for replacement suggestions. It's been a good antenna, but I wouldn't mind trying something different. TV reception is still important to us, but not as important, so something simpler might be fine.
Thoughts?
2015 Ram 1500
2004 Pioneer 18T6
Dutch_12078
Winters south, summers north
Posted: 05/23/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
There's still nothing better than the Winegard Sensar IV. The replacement head only should work for you since the rest is still there.
Winegard 24130 RVW-205 Sensar IV with Wingman - Replacement Head Only, White
Dutch
2001 GBM Landau 34' Class A
TurnThePage
North ID
Posted: 05/23/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't torn into it yet, but it looks like the damaged cable may just connect to the mast base with a boot covering it. Is that correct? Is it just a plain old RG59 cable? My RV is 2004 vintage.
IAMICHABOD
Sunny So Cal
Posted: 05/23/21 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought my RV it had a Winegard Batwing that was not working, I cleaned up all connections and tested to see if it was broken, it was,so I replaced it with a new bat wing then ran a Channel Scan I was not impressed with the amount of channels that I got. This was done in my driveway here in the south bay of So Calif about 30 miles from the transmitters, using my SensarPro.
I then went out and got a Wingman add on, that put my channel scan up to 85,but I had a clearance problem with the Wingman,it would hit my A/C unit when lowered.
So I opted to put a Jack Antenna Head on and my channel scan went up to 174
">][image]
TheJack replacement head Is Cheaper than the Winegard replacement head
I always get beat up by the techies,who will bring up a very old post that is not reverent now. The debate will go on and on, but I know what works best for me,in the real world.
* This post was edited 06/10/21 11:31am by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
craig7h
Branson MO area
Posted: 05/24/21 03:24am Link  |  Quote  |  Print  |  Notify Moderator
On a different coach I replaced the wingman batwing with a King Jack. King has a unit that is designed to go on the wingman setup.The Jack work well it was however a little more sensitive to direction than the wingman. On the other hand it pulled in a few more channels.
I also replaced on a different coach the King Jack with a Omni directional ant. The Mjg. had put the King to close to the ac cover so it blocked signal.
The coach I have now haa the wingman and if I had to replace it would be with the King Jack.
Itasca Meridian SE 36g
Road Master Tow Dolly
wildtoad
Blythewood, SC
Posted: 05/24/21 05:05am Link  |  Quote  |  Print  |  Notify Moderator
My experience tells me two things. First is the Winegard Sensar is the better overall setup. I’ve used the Jack and found it to be good but not as good. Second in the real world they all suck, but OTA TV has always been an iffy situation, unless you’re in close proximity of the broadcast towers. Many factors can interfere with reception as one day signal comes in clear, next day not so much. If you were happy with what you had, just replace it with a newer version.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Posted: 05/24/21 05:24am Link  |  Quote  |  Print  |  Notify Moderator
When that happened to me I got a Winegard Sensar IV (With intergrated Wingman)
Put a new end on the cable (Nice compression fitting. yes I have those)
and man did reception improve over the old III + Wingman. Turns out it needed replacement. or the cable end did. not sure which.
Posted: 05/24/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD wrote:
The Jack head Is Cheaper than the Winegard replacement head\
Yes it is but you get what you pay for. The two have been put to the comparison and the winegard outperformed the Jack, depending on the carrier channel, between 2 to one (1.414 the range) to a much higher difference (Been too long since I read that post on these forums)
Oh and consider replacing the indoor module with the Sensar Pro. Even better performance and easier shooting (Aiming of the antenna)
Dutch_12078
Posted: 05/24/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
One area where the Sensar really outshines the Jack is with the 400+ low VHF stations across the country. Here's a broadcast engineer's test results comparing the Sensar and the Jack:
Batwing vs.BatMan vs. Jack: The Results..
mobeewan
Hampton, Va
Posted: 05/24/21 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Could also be RG6 if trailer is wired for Satellite. RG6 will work for cable or tv antenna. RG6 copper center wire is thicker and stiffer than RG59.
I wired both satellite and roof top tv antennae in my fathers house and the house across the street I used to live in, all with RG6. Both dishes had dual LNB. Bought a 500 foot spool of RG6 cable back then for $50.
