RV.Net Open Roads Forum: Morryde Suspension and Wet Bolt Upgrade
 > Morryde Suspension and Wet Bolt Upgrade
1L243
Oregon
Posted: 05/23/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have been wanting to upgrade the suspension on my 2017 Coleman 300tq Toy Hauler with Morryde CRE 3000 and the Wet Bolt kit. I ran into a couple of minor issues durring the installation that I thought I would mention them here.
My Rig only has about 7000 miles on it (off the top of my head guess). The stock components were in pretty good shape. the plastic leaf spring bushing were still in good shape.
The Morryde system replaces the plastic bushings with bronze bushings. The wet bolts will allow you to grease the bushings and moving parts. The shackles are at least twice the thickness of the OEM shackles.
The installation instructions call for raising the trailer so both axles are off the ground on both sides. For me this was a problem because I had just enough jack stands, blocks and jacks for doing one side at a time.
The old
The problem I ran into was getting the leaf springs to line up with the leaf spring bracket and the Morryde equalizer. I am pretty sure this is because I am doing one side of the trailer at a time.
I used a small hydraulic bottle jack to push down on the axle to line up the bolts and I used a ratchet strap to line up the leaf spring with the frame hanger. Besides that everything went pretty smoothly. Took me about 5 hours but I was taking my time.
The New
You have the choice during the installation to face the grease fitting to the inside or outside. My axles are 4400 lb 33 inch on center and I placed them facing out. I can get to them easily without removing he tires. Your application could be different and putting the grease fitting facing in for easier access.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
path1
Varies with weather
Posted: 05/23/21 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Looks great..I've been thinking about the same project.
Do you happen to know if it raised your rv, if so how much?
1L243
Oregon
Posted: 05/23/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had to push down on the leaf spring to get it to line up with the new Morryde equalizer so I would not be surprised if it raised it. My guess would be a inch or less. I say that because they claim you will get a extra inch of suspension travel with the Morryde CRE 3000 and they may have done that by raising the ride height.
That's just a guess I have to measure it know for sure.
kfp673
PA
Posted: 05/25/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Did this 2 months ago as well. Thanks to this forum, I also learned that greasing is much easier with weight off the springs. I had 4 points not take grease until I jacked it back up and then no problem.
One thing I am considering is adding the X factor cross member. did you do that? Anyone do that with the 3000?
1L243
Oregon
Posted: 05/25/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I was thinking of going with the X Factor cross bar. Not only for front and rear axles but for the Equalizer hanger as well.
BUT
I have a problem with the Black tank drain pipe running in front of the front axle hanger bracket PLUS the Gray Tank drain pipe runs in front of the rear axle hanger bracket.
If, I get real excited to do this I may reroute some plumbing but for now it's on the back burner.
1L243
Oregon
Posted: 05/26/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to add to my own conversation about the X Factor Crossmember. I think due to the plumbing routing concerns I have for the front and rear axle hanger crossmember, I will be going with the center Equalizer bracket only.
I saw a video recently where the owner had a welding shop box one end of the front and rear axle hanger bracket. This adds strength to the hanger bracket making it less likely to fail.
So that the plan!
Posted: 05/26/21 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
10-4
If the port in the bolt is facing up (no way to tell from the outside ) then you’re effectively fighting the weight on the bolt when trying to grease.
2017 Heartland Torque T29
Vintage465
Prunedale CA.
Posted: 06/07/21 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Nice job! The CRE3000 is a great upgrade. I faced the zerks on mine to the inside. Not sure it's easier, but I have to get under the coach anyway to set the jack to lift the axle prior to greasing anyway.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
Cummins12V98
on the road
Posted: 06/07/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
IMHO for the time, money and you still have drum brakes a set of these would have been well worth the Coin.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Vintage465
Prunedale CA.
Posted: 06/07/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I think you need to add "a lot" before coin and "s" to the word coin. Disk brakes are nice and better. Drum brakes have been working for years.
* This post was edited 06/07/21 05:34pm by an administrator/moderator *
