RV.Net Open Roads Forum: Class C Motorhomes: Cleaning up our old RV
 > Cleaning up our old RV
EMD360
Arvada, CO
Posted: 05/23/21 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve been working on the old RV the last several days. I knew I wanted to replace some eternabond on the rear corners and across the back trim. I replaced some missing vinyl trim on the front seams and re-caulked. I’m terrible with caulk. Messy and uneven but better to have new caulk than not. Also caulked between the old and new vinyl trim.
Underneath is especially hard to caulk. I did a little better above.
I have a day night shade to restring and I have general clean up to do. I de-winterized it and I stain treated the carpet and I’m going to shampoo it. I’m debating whether to wax it. The decals are in bad shape and it’s clean. Seems like wax would be putting lipstick on a pig.
* This post was edited 05/24/21 09:50am by an administrator/moderator *
jdc1
Rescue, Ca
Posted: 05/24/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
But, every little bit helps.
wolfe10
Posted: 05/24/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
The secret to a good caulk job is blue painter's tape on both sides of what you are caulking.
Run a bead, smooth with your finger or tool. Immediately pull tape and again smooth.
Some caulk products are much easier to work with than others. Though silicone products are not my favorite, the smooth very well with a wet finger.
Practice on a piece of scrap or even cardboard.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
EMD360
Arvada, CO
Posted: 05/24/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I’m using non-sag dicor. That is what I usually use. I tried Sikaflex but found it even harder to work with. I should use painters tape since I’m such a slob. Good idea.
It is not soap and water cleanup which is the easiest caulk but I’ve not seen one recommended for RV’s.
EMD360
Arvada, CO
Posted: 05/24/21 11:40am Link  |  Quote  |  Print  |  Notify Moderator
I found that the kitchen sink sprayer was cracked for the third time when dewinterizibg. I’m not sure what I’m doing wrong. I run the fluid through it. I have to pick up a new one. At least it appears to only be the spray part and not the hose. Although I’m confused that when I took off the sprayer the entire faucet stopped working. I don’t see it leaking anywhere. Another quirky problem.
gkainz
Arvada, CO, USA
Posted: 05/24/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy, neighbor! Good work! [emoticon]
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
EMD360
Arvada, CO
Posted: 05/24/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy fellow RV’er! Any luck getting camping sites? Ha ha. Do it early. Just got one for a weekend in late Sept. Moraine and Aspen Glen are full!
gkainz
Arvada, CO, USA
Posted: 05/25/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
We tried to get Grand Lake for July 4th weekend and struck out just 12 hours into the reservation slot, so we're boon-docking at a friend's cabin near Leadville.
We normally camp every other weekend all summer from May through October but this year we definitely missed the boat for reservations.
We did get Sylvan Lake for end of September.
capacitor
California
Posted: 05/25/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Looks as though we have two topics going on?
jjrbus
FT Myers FL
Posted: 05/25/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
A decent caulk gun makes a big difference. Most go to Home Depot or such and spend $4 on a ratcheting caulk gun. Unless you are incredibly gifted it is **** near impossible to do a decent job as they cannot provide a steady flow. A $20 smooth rod caulk gun makes a BIG difference. Google caulking tips before you try again.
