RV.Net Open Roads Forum: General RVing Issues: LP or electric on a meter
 > LP or electric on a meter
blaczero
Posted: 05/24/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone, I have a seasonal site where I have metered electric, so for fridge, heat and hot water, is LP or electric cheaper?
Posted: 05/24/21 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Generally LP is cheaper..
HOWEVER it depends on how much you pay per unit for each and sadly I do not have the conversion factors handy.
johnhicks
Wandering below the Gnat Line
Posted: 05/24/21 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I's seen written a few times that $2 a gallon is approximately equal to 10 cents per kWh.
-jbh-
valhalla360
No paticular place.
Posted: 05/24/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Cost really is a non-issue in the choice.
Unless you use a ton of propane, the convenience of electric makes it worth paying an extra $5-10 per year with electricity.
If you use that much on a seasonal site, see about getting a propane company to bring out a big 100gal tank but unless you do a lot of winter camping, it's unlikely to be worth it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
blaczero
Posted: 05/24/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Back in April (when it was cold) I was using 1 30lb / week LP. The ppl here at the campground said it'd be cheaper than electric.
I suppose the question would be, is the fridge and hot water cheaper on LP too?
I have not received my first bill yet, so I am not sure how much they're charging / KWh
DrewE
Vermont
Posted: 05/24/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
The water heater and fridge use comparatively little energy when compared to the furnace/heaters. Absorption fridges tend to run at very roughly a pound of propane a day, or maybe 3ish kWh per day. The difference between those costs is probably on the order of a few cents. The water heater is probably similar in cost to operate.
(For the water heater especially, it's a bit more likely that electricity will be cheaper because the immersion element is considerably more efficient than the burner in terms of lost energy: virtually all of the energy it uses goes towards heating the water, while a portion of the heat from the gas burner escapes with the exhaust.)
Lantley
Ellicott City, Maryland
Posted: 05/24/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
This^^^^. Why go through the effort of monitoring and changing tanks.
Electric does not require any input from the end user.
The cost difference is negligible either way.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
HappyKayakers
Somewhere in the USA
Posted: 05/24/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I found this link several years ago. Can't vouch for the figures but it looked like someone did their homework. http://www.adventure.1tree.net/index.php........m_content&view=article&id=292&Itemid=285
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
Cummins12V98
on the road
Posted: 05/24/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Think about your time and vehicle wear and tear plus fuel consumption to take the tanks to be filled. I really don't care about the cost I run electric when possible for everything.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Old-Biscuit
Verde Valley
Posted: 05/24/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
A few bucks either way
Electric is so much easier
Fridge.... might have TWO 225W elements (large size) or ONE 375W element (medium size)
Propane ---1200btu to 2200btu depending on size of fridge
Water heater.....
Atwood 6 gal 8kbtu/hr --10kbtu/hr 10 gal ---1400W element
Suburban 6,10,12,16 gal---12Kbtu/hr run time ---1440W element
Do the math
OR
Use the electric it isn't going to be that costly
US NAVY------USS Decatur DDG31
