RV.Net Open Roads Forum: Tech Issues: Fresh Water Drain
 > Fresh Water Drain
mikemc53
NC Florida
Posted: 05/24/21 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Just purchased a 2021 Gulf Stream Class C Conquest 6250D. Does anyone know if there is a specific drain for the fresh water tank or do I need to just run it dry with the pump? My Class A has a large valve that will drain the tank itself but I have been unable to find one on this. It has low point drains but they likely will only drain what is in the lines and then I would need to run the pump anyway - wouldn't I? It was winterized at the factory and now I need to clear the tank and the lines.
Thanks gang.
2021 Gulf Stream Conquest 6250 (Class C)
jdc1
Rescue, Ca
Posted: 05/24/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
That's one thing that should have been disclosed during your walk-through.
IAMICHABOD
Sunny So Cal
Posted: 05/24/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
WOW that was helpful [emoticon] smh
Former El Monte RV Rental
Buying A Rental Class C
madjack60
littleton
Posted: 05/24/21 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Some will be under the bed if it is storage underneath, some are in the compartment for the storage. You can Google that question for your model and there may be a YouTube video for it
madjack60
littleton
Posted: 05/24/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Also, there should be a manual with the unit and it will tell you all you need to know
Near DVNP, California
Posted: 05/24/21 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Go underneath your new C with eye protection and a flashlight. You’ll find it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
DavidandDayle
Guelph, Ont
Posted: 05/24/21 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Ours has a tap at the back corner on the driver's side. (Not your make or model). If you can see the tank, look for a line coming out of it other than to the pump. trace this.
David and Dayle
bikendan
Camano Island, Wash.
Posted: 05/25/21 02:57am Link  |  Quote  |  Print  |  Notify Moderator
that's not true. most RV manufacturers only provide a generic owners manual, with no model-specific information.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
maillemaker
office
Posted: 05/27/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
My 1990 Winnebago Warrior has 4 low-point drains. If you open them all and open your faucets the entire system will drain, tanks, lines, and all. No need to run the pump.
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
 > Fresh Water Drain
