RV.Net Open Roads Forum: Tech Issues: Propane experts
 > Propane experts
spud1957
NB
Posted: 05/25/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
I have two tanks one on each side of the 5th wheel. Regulator/change over is road side. The tank field side tank has what it looks like some sort of regulator between the rubber hose and the metal pipe that goes over to the regulator road side.
This component has some kind of blow off valve that's blowing off what appears to be propane when I turn on the tank connected to it.
My question is what is this?
S
Roger10378
Goodrich, MI.
Posted: 05/25/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
It is also a regulator, it reduces the pressure to about 10 psi. It is a safety item so that there is not full tank pressure in the line going across the unit. It has failed and needs to be replaced.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Old-Biscuit
Verde Valley
Posted: 05/25/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
That is a 30# LP REg....diaphragm is cracked if propane is coming out of vent
Commonly called Red Top LP Reg
It is required due to long line across front of RV from side to side
Full cylinder pressure could condense in that line and cause liquid propane to flow to Changeover Reg destroying it and possibly putting liquid propane into RV Propane System
Marshall Excelsior MEGR-130-30 High Pressure Regulator
About $14 on Amazon
* This post was edited 05/25/21 12:57pm by Old-Biscuit *
US NAVY------USS Decatur DDG31
time2roll
Posted: 05/25/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
The high pressure regulator is required to prevent condensation of propane in the cross over line. Required when the connection is over 5' in length. If the RV is older than 5 years I would replace both regulators.
675w Solar pictures back up
BB_TX
McKinney, Texas
Posted: 05/25/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
What Old-Bisquit said. Required by National Fire Protection Association standard for RVs.
Mine started leaking from the vent hole and I replaced it with a Marshall years ago. Better regulator than the OEM.
spud1957
NB
Posted: 05/25/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys.
 > Propane experts
