RV.Net Open Roads Forum: Truck Campers: Heavy duty hitch extension??
 > Heavy duty hitch extension??
TxGearhead
Posted: 05/25/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
If you're hauling a "race" trailer you've likely seen a toter. Only brand I can think of of the top of my head is Haulmark.
Buying a used one with about the same size or bigger than a cabover wouldn't be that much more $ than what you have in your truck and a new camper.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
8wj2r5w
Arizona
Posted: 05/25/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
This isn't a money thing for me. I don't want to drive around with 75+ feet. I love my truck and trailer setup currently. I don't need anything more than a camper as far as living quarters.
PastorCharlie
NC
Posted: 05/25/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Install a larger receiver on truck with 3" opening and custom build an extension the length needed out of HD square tubing. Brace it on both sided from rear to truck hitch in triangles to prevent any movement sideways.
If needed use bridge strap on top of extension tube to increase load capacity.
3 tons
NV.
Posted: 05/25/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Might work, but who’s gonna certify its abilities??...No certification means no confidence...
BradW
Mayor of Flat Rock
Posted: 05/25/21 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Two words: Super C
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
rlw999
Washington State
Posted: 05/25/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds a little light for a 2000 tongue weight when even the heavy duty Torklift extender that he found (which is a dual-receiver extender, the heavy duty Torklift hitch has 2 receivers, one on top of the other) is only rated for 1200 lbs. I know you said to use a "bridge strap", but it's not clear where he'd anchor it once the TC is on the truck.
deltabravo
Spokane, WA
Posted: 05/25/21 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
I had an Arctic Fox 811 and on one trip I towed 10k worth of 8.5x20 trailer with a Jeep in it.
It was not a pleasant experience. I will never tow that much again while hauling a camper unless I had a heavier truck... F450 or better.
ticki2
NH
Posted: 05/26/21 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Get to the scales with your present truck and trailer loaded , that will tell you how much capacity you have left on the rear axle and tires . You are probably limited to a small camper with no overhand so no extension hitch .
'68 Avion C-11
'02 GMC DRW D/A flatbed
SpeakEasy
Western New York
Posted: 05/26/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I can't show you the math, but I can tell you that extending your hitch length has an enormous effect on tongue weight. Think of a lever and the leverage effect. I think the physics of it is sort of the reverse of a weight-distribution system.
I'm sure some of the engineers on this forum can jump in here and explain mathematically what it is that I'm referring to.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
NRALIFR
Let’s Go Girls! [End of Quote]
Posted: 05/26/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
OP, how long is your race trailer? How long is the bed on a Mega Cab dually Ram, and what’s the overall length bumper to bumper?
If you’re determined to keep your current truck (totally get that, btw) then due to the >2K tongue weight, you would probably be best served by sticking with a truck camper with no or minimal overhang beyond the rear bumper, and using NO hitch extension.
If you decide to extend the tongue of the trailer, be aware that some TC’s that are longer than the truck bed drop down quite a bit behind the rear bumper. Mine is a good example of that. You can’t see the truck bumper at all from the rear, and an extended tongue would very likely contact the camper bumper at times.
Now about that Automated Safety Hitch System. Yes, it looks “crazy”, and “an expensive pile of things that can go wrong”. That’s what’s usually said about it at first glance by those who have never seen one. But, if you’d take the time to read the mfgr’s web site, and watch a few of the videos, you’d see that this is no shade-tree contraption.
While it does lengthen the total combination, and may therefore be unsuitable if you need to stay under 65’, here’s a few of the fine points:
It can pull Gooseneck Trailers, 5th Wheel RVs, Travel Trailers & Bumper Pull Trailers.
It attaches to the truck with a three-point system.
It doesn’t pivot side to side. The axle steers in a turn.
It has its own hydraulic brakes.
They are no more unsafe or ill-conceived than the semi-trailer dollys used to tow doubles. Unlike the dollys though, they DON’T add a pivot point.
While they aren’t common, I have seen them being used. The owners always like them.
But, that’s all I’m going to say about them. I don’t intend to turn the topic into a discussion of this product. I just hate to see it dismissed so quickly.
[emoticon][emoticon]
