RV.Net Open Roads Forum: Truck Campers: Heavy duty hitch extension??
 > Heavy duty hitch extension??
noteven
Turtle Island
Posted: 05/26/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
When you look at a commercial truck pulling a pony or stiff hitch trailer (RV world: bumper pull) the hitch on the truck is only allowed to be offset so far from the center of the rear axle or axle group.
A little on line research into maximum hitch offset may discover some info to help in decisions.
* This post was edited 05/27/21 06:49am by noteven *
mkirsch
Rochester, NY
Posted: 05/26/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
NRALIFR wrote:
I think if I was wanting to haul a truck camper and tow a trailer with that much tongue weight, I’d be looking at this:
Automated Safety Hitch
[emoticon][emoticon]
Is that company even in business anymore? That is an OLD website. People have been asking about/recommending it since I joined this site in 2004.
valhalla360
No paticular place.
Posted: 05/26/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
SpeakEasy wrote:
I can't show you the math, but I can tell you that extending your hitch length has an enormous effect on tongue weight. Think of a lever and the leverage effect. I think the physics of it is sort of the reverse of a weight-distribution system.
I'm sure some of the engineers on this forum can jump in here and explain mathematically what it is that I'm referring to.
-Speak
Yes, it drastically increases some of the forces that can be applied to the truck.
Problem is people see the static hitch weight and don't understand in real life towing, there are dynamic forces involved where the hitch weight and the lever arm come into play.
5th wheels tow very well because the hitch sits right over the axle and can't apply any torque. Bumper pulls aren't as good because there is typically 3-4 ft where the hitch can apply leverage...now add a few more feet and with a very large bumper pull and it just gets out of hand real quick.
Even in the static condition, that's likely going to add 3000lb to the rear axle, so with a big heavy truck camper, good chance the rear axle is overloaded even on a dually.
As someone else said, get a shorter truck camper, so you can use a standard hitch or move up to a commercial truck with drastically higher capability.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
Indepmo
Posted: 05/26/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
It looks like the safety hitch floats up/down in relation to to TV. If the camper overhangs the back of bed the tongue would hit.
NRALIFR
Truck Camping Out West
Posted: 05/26/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
It does, and it could. Depends on the camper and the truck it’s on. Not every 10-12 ft camper hangs down as much as mine does. Fitment is the operators responsibility just like with an extended hitch. I’d sooner tow a heavy race trailer with the Automated Safety Hitch than any extended hitch though.
As far as the company is concerned, I have no idea if they’re still around or not. The website makes it appear that they’re still in business, and it has a 2021 copyright on it, if that means anything.
noteven
Turtle Island
Posted: 05/27/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
What part of how an Automated Safety Hitch or an Idaho Tote works don’t folks understand?
They attach in 2 places so they don’t pivot like a trailer. The axle has brakes. They self steer. They carry a load or hitch load...
This concept is not new or physics defying... see concrete mixers with booster axles or dump trucks with flying tag axles.
Small simple versions were found under whatchamacallit truck campers back 30 or 40 year ago.
AnEv942
CA
Posted: 05/27/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Noted OP says not really interested in product, but question about if Automated Safety Hitch still available prompted me to send email and ask. Below is note I received from them.
{ sales/safetyhitch.com
We have been in business delivering Automated Safety Hitch since August, 2008 without interruption. Presently we are delivering 22 per month, soon to be 44 then 66 or 88 per month.
We expect to have ten production lines, (two shifts), open by years end with each production line producing an average 22 per month.
We are signing on dealers so that nobody in North America will have to travel more than 150 miles to see one and experience riding in a demonstration.
Thank you for asking,
Michele }
JRscooby
Indepmo
Posted: 05/27/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Even if the bottom of camper does not drop below bed level, but extends 2 feet behind the bed clearance could be nothing pulling in a drive off a crowned street. 4 feet? Might hear a bang crossing a bridge. Now I do agree, more axles are better, and a long extension on hitch is a bad idea.
Extended tongue, still need to worry about bottom of camper, but less weight on drive axle, less increase in OAL
If you look at trucks with a axle made like that, there is nothing to stop upward travel of that axle. With the thing pushed in this thread, it must have a hinge so it can float up/down, or the vehicle could not be controlled on uneven ground.
Pete_k
Stantonville Tn
Posted: 10/10/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Here you go and this guy is doing it Commercial. 3500 ram with the trailer extended to the factory hitch.
[image]Click For Full-Size Image.
2022 Ram Big Horn DRW on order">
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
2012 Landmark Key Largo soon to turn into a Truck camper.
jimh425
Western MT
Posted: 10/10/21 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like he needs a weight distribution hitch, air bags, or both.
