RV.Net Open Roads Forum: Travel Trailers: Triple bunk Travel trailer under 36'
 > Triple bunk Travel trailer under 36'
momma03monsters
Pittsburgh PA
Posted: 05/25/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I am looking for a triple bunk travel trailer, bumper pull that is under 36'. We will be pulling with a 2021 Ram1500, towing capacity of 11,000lbs. We have 3 small children and 2 dogs that we would like to camp with, and would like to upgrade to a travel trailer from tent camping. So far, we really like the Coachmen Freedom Express 292bhds. Are there other trailers out there that are similar in layout? The outdoor kitchen is a huge bonus, but not needed.
camp-n-family
London, Ontario
Posted: 05/25/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to rethink this. A 36’ trailer is a lot for a half ton truck. You may have an 11k tow rating but that is useless when you don’t have the payload to carry the tongue weight plus 5 passengers and 2 dogs.
Get your truck payload off the door sticker and subtract the weight of all passengers and stuff in the truck. What’s left is available for the trailer tongue weight. Figure 13% of the trailer weight is on the tongue (for good stability) and leave a little room to spare.
Most half tons will max out with 7500lbs trailers or less. Know your numbers and don’t be fooled by the sales gimmick tow ratings. Many people here have made this costly mistake and quickly ended up spending a ton getting a bigger truck.
* This post was edited 05/25/21 03:19pm by camp-n-family *
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
theoldwizard1
SE MI
Posted: 05/26/21 01:15am Link  |  Quote  |  Print  |  Notify Moderator
True "bunk house" trailers are hard to find, but there are a few out there. That is a lot of trailer for a 1/2 ton truck! Make sure the tanks are empty and don't overload the bed.
GrandpaKip
Flat Rock
Posted: 05/26/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
That trailer will have a tongue weight approaching 1000 pounds when loaded. Take that from your payload sticker and see what you’ve got left.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Mickeyfan0805
SE Wisconsin
Posted: 05/26/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
As others have said, you do need to watch your weights, but the only way to do that for sure is for you to look at YOUR numbers and not the assumptions of many on either side of the debate. I will tell you that we tow a very similar trailer in floorplan, length and weight with our F150. We are within all of our weights, but we travel with minimal fluids and nothing in the bed of the truck in order to stay well within those ranges.
I will also say that, unless you are taking 2 vehicles, the dogs will become a problem in a hurry. Hard to travel with 3 growing kids and 2 dogs in the cab of a pick-up. Our dog has to stay home for any trip longer than a few hours (where we are not taking 2 cars).
With all of that said, this floorplan is much like ours and it has worked very well for our family of 5. I will simply add that the outdoor kitchen is an absolute necessity for us. As the kids get older (ours are not 12, 15 and 16), the interior of that camper gets increasingly small. Being able to cook outside makes all the difference in keeping the center area of the camper from becoming overly cramped with people and stuff during meal times.
momma03monsters
Pittsburgh PA
Posted: 05/26/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
We will most likely not be traveling with both dogs, as they are older and we are still in the research process. Most likely when we do get the travel trailer, it will only be one large dog(most likely a GSD). We plan to travel with very low liquids and maybe only our bicycles in the bed of the truck. If you don't mind my asking, what trailer do you have?
Mickeyfan0805
SE Wisconsin
Posted: 05/26/21 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Rockwood 8312ss. It's a 2013. They don't make that model anymore. We've had it coming up on 9 years and have been very happy with it. I expect we'll hold onto it until it's just DW and me.
spoon059
Just north of D.C.
Posted: 05/26/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Jayco 29QBS. Triple bunks in a rear bunk "room". Its a 9500 lbs trailer, tongue weight will be way too high for a Ram 1500. Half ton Rams have pretty low payload. You will NOT like towing a 36' trailer, or anything close to 11,000 lbs with that truck. Either do it right or don't do it at all.
If you're gonna keep the Ram, look at a hybrid for bunk beds and a popout bed for the kids. Otherwise, look for a truck with substantially more payload (2000 lbs +, those kids are going to continue to grow and want to bring bikes, toys, etc)
2015 Ram CTD
2015 Jayco 29QBS
Thermoguy
Graham, WA
Posted: 05/27/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
In my opinion, this is a bad recommendation. If you have to travel with limited or no fluids in your trailer, then you have the wrong trailer or wrong truck. You should be able to haul your trailer with the tanks all full. With very limited options to camp in a campsite with full services like dump and water, you often have to boondock if you want to go camping. If you boondock, you have to start with a full tank of water, that tank will be mostly empty on the way home but then the grey and black are full - or mostly full. We have had to fill 5 gallon jugs and add fresh water to get through a few day boondocking trip, for showers, etc. The trip home I have a very heavy trailer, full tanks, typically some water still in the fresh tank. When boondocking, your not going to have services near by. You might have to drive over a pass, large hill, or miles to the nearest services. Do you want to have your setup overloaded? Best to consider the real full weights then make a decision based on that. Plan ahead, not the opposite.
Mickeyfan0805
SE Wisconsin
Posted: 05/27/21 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I'm all for planning ahead and being thoughtful about weights. That said, we are in our 12th season of camping as a family and have never one boondocked. What might seem 'necessary' to some is never on the radar for another. We all do this differently, and our plans and expectations should match our particular usage.
