RV.Net Open Roads Forum: Truck Campers: Stable Camper anti-rocking system
 > Stable Camper anti-rocking system
n0arp
FT
Posted: 05/28/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Works great. We also use them to stabilize the camper when removing or loading it in windy/gusty conditions by locking them in or removing them as you go through the process. Makes it much safer/ less risky.
We usually will lower the camper all the way down even with the StableCampers, but it's far more stable even lowered with them than lowered without them.
* This post was edited 05/28/21 08:39am by an administrator/moderator *
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
errante
travelin
Posted: 05/28/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Jshupe, not to change the subject but unless I missed it, you should post in a new thread about your solar panel layout.
n0arp
FT
Posted: 05/28/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
It's mentioned in this build thread, but I stopped posting in the thread after a while. Didn't seem to have much interest.
The rack adds about 1" to the total height, with the AC unit tucked up between the rails -- we've put about 9K miles on the camper since adding it, without issue. It used to be a couple inches higher but I reworked it to hover just over the AC unit, to make up for the height gain I'll get from a flatbed I'm having built.
It has 5x360W REC Alpha panels for 1800W total. They're wired in series into a Victron 250/60 controller with a 11.8kWh 48V bank.
Highway Runner
Atlanta, Ga.
Posted: 05/28/21 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed my Stablecamper rods this week and it certainly helps. They take out most of the wobble. I would spend the money again.
2015 Eagle Cap 1165
2016 F-350 Lariat 4x4, 6.2 Boss Dually, 4.30 Axle
Air Lifter 7500 XL w Rancho 9000s & Torklift Stable Loads
Slymer
Ontario, Canada
Posted: 05/28/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks MORSNOW Makes perfect sense now,..but I don't have that feature with our AF811,..even though it is the same manufacturer. Thanks for the input.
I wonder how long it will be before manufacturers start making campers & jacks that will ALLOW the bottom of the camper to actually make contact with terraferma to alleviate any sway at all. Would solve a lot of issues. ie; no more stairs needed,just walk right in,...until you load it back on the truck.
* This post was edited 05/28/21 04:32pm by Slymer *
650cent
Madras, OR
Posted: 05/29/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Made in Sandy, Oregon. The stabilizers work as advertised and its one of the best things I have bought for the camper yet.
Bill
Slymer
Ontario, Canada
Posted: 06/09/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks. I just pulled the trigger yesterday. Could be a 1 - 2 month wait for delivery though.
Slymer
Ontario, Canada
Posted: 08/19/21 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Got it all installed & just spent two weeks in it,....off truck.       What an amazing difference.       Not perfect,......but very darn close.      Easy install too.
wintersun
Monterey
Posted: 08/20/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
My camper when off the truck has always been lowered to where it is less than a foot above the ground and no chance of flexing of the legs. There is an assumption that the extra bracing is going to be attached to a solid part of the camper and often this will not be the case.
burningman
Seattle, WA USA
Posted: 08/21/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
A couple 4’ 4x4s and a set of jack stands will make a camper way more solid and secure than these jack braces ever can, for way less money and no waiting.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
