RV.Net Open Roads Forum: Travel Trailers: 30 to 50 adaptor hot?
 > 30 to 50 adaptor hot?
DinTulsa
Tulsa
Posted: 05/26/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Currently have the rv at the house and I have the 1 ac running and the fridge at this time. The 30 to 50 adaptor is hot at the 50/50 connection, not where the 30 plugs into the wall. Is this normal, or due to a faulty adaptor?
And by hot I don’t mean burn you hot, as I can hold onto it without pain, just really warm.
JRscooby
Indepmo
Posted: 05/26/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Unplug. Use 2 pair of pliers to put a little twist in each blade. This will tighten the contact
time2roll
Posted: 05/26/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yes heat in the adapters is common. Not going to say normal as many are poorly made. Keep a watch on it. For best results set the fridge and water to propane when running the A/C for extended periods.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 05/26/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
A little heat is common. if it is hot there is a loose connection.
Have you noticed heat when plugged directly into a fifty amp receptacle? If heat is not present, then female receptacle on adapter is issue.
Molded receptacles are harder to fix. some you can use small screw drivers to squeeze them tighter. One on each side and prior outward.
The male end may have "wafered" blades. Look closely at them. If they are use a knife or small screw driver to separate slightly so it fits into the adapter.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dodge guy
Bartlett IL
Posted: 05/26/21 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
How many amps are pulling? However it Sounds like you have a loose connection.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
BB_TX
McKinney, Texas
Posted: 05/26/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Bad contacts or bad wire connection in one of the other. Bad connection equals resistance equals heat.
DinTulsa
Tulsa
Posted: 05/27/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I appreciate the feedback. After a little more research I found that my outside fridge was running as well. So I had my outside fridge, inside fridge and ac pulling on the 30. There may be a little bit of a loose connection as well, but it had a pretty good load on it. Normally if I’m in a park and I don’t have 50a to grab, I’ll
Plug the outside fridge into a 110 extension cord.
enblethen
Moses Lake, WA
Posted: 05/27/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Make sure 120 volt water heater is off, if equipped.
betito
North Carolina
Posted: 05/28/21 04:48am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, if you were already putting load than capacity, there are possibility of heat. still, unplug other appliances and test the adaptor only with your ac and fridge.
lenr
Indianapolis, IN
Posted: 05/28/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Lots of good advice on cutting the load on the adapter. However, to be clear if the 50 amp end is warm and the 30 amp end is not there is a problem with the 50 amp end that must be fixed. If left unattended, warm connections usually turn into hot connections that will start deteriorating the 50 male prongs. Most likely the problem is in the 50 amp female as covered above.
