RV.Net Open Roads Forum: Tech Issues: Fridge on the Fritz
 > Fridge on the Fritz
Quadcab
SW Lower Michigan
Posted: 05/26/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Just plugged in the gas/electric fridge on our 2018 Crusader Lite 5th wheel and it will not turn on!? Gas is on, I double checked that. Electrical is working. The power button once pressed will show "green" light for about 3 seconds, then turns "red" and says to check the gas supply. Is there a simple fix that I am just not thinking of? Really feeling ignorant right now - like this should be obvious. Any help would be appreciated as my DW is worried this will affect our weekend camping plans.
Quadcab
2018 Titan XD 5.6 V8 Kingcab
2018 PT Crusader Lite 28RL
enblethen
Moses Lake, WA
Posted: 05/26/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Light your stove top to insure good flow of propane.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Quadcab
SW Lower Michigan
Posted: 05/26/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, gas has good flow the the range. Still fridge will not turn on.
enblethen
Moses Lake, WA
Posted: 05/26/21 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Do you hear the ignitor clicking?
Did you try the refer a couple times to insure it has propane?
Quadcab
SW Lower Michigan
Posted: 05/26/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Did not hear the ignitor, but have tried all day to get the fridge up & running without success. Should I unplug the electrical to let it reset? Thanks for your help BTW.
enblethen
Moses Lake, WA
Posted: 05/26/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check the fuses on circuit board?
Did you smell gas?
Make and model of refer?
Step back and take a deep breath for tonight!
MrWizard
Traveling
Posted: 05/27/21 12:25am Link  |  Quote  |  Print  |  Notify Moderator
How long has it been since you used the RV,
Has It been sitting idle since covid 19 started
The gas jet orfice is clogged, turn off the LP
And blow the dust & spider webs out of the burner, THE flow tube, and the Orfice
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/27/21 01:40am Link  |  Quote  |  Print  |  Notify Moderator
A hint
Has electrical can mean
AC
DC
BOTH
Scottiemom
Posted: 05/27/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Since you are in SW Michigan, you are not far from Shipshewana, Indiana. Give Glenn Miller a call at National Refrigeration at 260-768-7059. You will not be disappointed. He will troubleshoot your fridge and fix it and he doesn't charge an arm and a leg. He's an Amish man, very honest, etc. He bought the business from Leon Hershberger and has relocated on SR120 north of Shipshewana about 1 1/4 miles. It's on a curve, new building. . . you can't miss it.
Address is 6755 W SR 120, Shipshewana.
He's troubleshooted mine a few weeks ago. Spent 45 minutes on it and didn't charge me. He couldn't fix it, but it wasn't the fridge. . . it was an electrical problem at the outlet. A friend in the campground (an electrical engineer) fixed it. That same friend had to run over to Shipshewana the next week and have Glenn change out the cooling unit in his fridge for $1100. Running great now, but his boiler had ruptured.
He will fix you up for sure.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
wolfe10
Posted: 05/27/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
In order:
Verify 12+ VDC to the terminals accessible from the outside refrigerator compartment door. The PC board runs on 12 VDC as do the ignitor and gas valve.
Have someone turn it on (set to gas) and tell us how far into the cycle you get:
Hear clicking of ignitor
Hear/feel gas valve openging
Smell gas or see flame
Flame stays lit
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
