RV.Net Open Roads Forum: Fifth-Wheels: Electrical problem with front stabilizers. Update.
 > Electrical problem with front stabilizers. Update.
fj12ryder
Platte City, MO
Posted: 05/27/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, I need some suggestions, hints, or outright solutions.
I have a 2010 Keystone Fuzion 383, a 40' toyhauler. It has been in storage for the last few months. The battery has been on a Battery Tender in the heated garage at home. When I went out to bring it home, I installed the battery and the front stabilizers wouldn't do anything. They are the Bulldog double motor stabilizers. When the rocker switch was moved, nothing happened, no noise, no nothing. Having few tools to work with, I jumped directly from the battery and the motors would then operate as they should. That got me home.
At home I've checked the wiring, and there is 12 volts to the rocker switch, but that voltage drops to 0 Volts when the switch is moved, and then goes back to 12 Volts when the switch is released. But voltage checked directly at the battery doesn't change in the least, steady 12.5 volts. However I can run a wire directly from the battery to the 12 volt terminal on the rocker switch and the motors work as they should. I have the remote control fob for slides, stabilizers, awning, and they all work, but the front stabilizers don't work using the remote. All fuses in the control panel look good.
Any help or suggestions would be greatly appreciated. TIA.
* This post was edited 05/29/21 01:15pm by fj12ryder *
Howard and Peggy
"Don't Panic"
CA Traveler
The Western States
Posted: 05/27/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
You have a high resistance open and hence no voltage under load. One of many possibilities is a loose connection or a cooroded connection.
Often you can put a load on the wire like a light bulb and it will not light because it's a low resistance load.
2014 Grand Cherokee Overland
Bob
fj12ryder
Platte City, MO
Posted: 05/27/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. I can do simple electrics, but this kind of stuff just makes me go "Duh".
MFL
Midwest
Posted: 05/27/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the breaker near the battery, most often on the inside basement wall? You could bypass that with a jumper, as they can get weak, or fail over time.
Jerry
fj12ryder
Platte City, MO
Posted: 05/27/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you Jerry, I'll give that a check too. We are leaving Tuesday so I've got a few days yet. Worse comes to worst I'll run a wire directly from the battery to the switch. Easy to do, but would rather fix the problem than use a doofer.
CA Traveler
The Western States
Posted: 05/27/21 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Add a fuse or CB at the battery end to temp wiring.
fj12ryder
Platte City, MO
Posted: 05/27/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Good idea, thank you.
Flute Man
Payson, Arizona
Posted: 05/27/21 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
If I were you, I would trace the wire all the way from the battery to the motor to locate corroded or high resistance connection.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
fj12ryder
Platte City, MO
Posted: 05/28/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Thank you, I've tried to do that, but they don't go directly to the battery. The wires disappear up though the floor, and out through the walls, so it's very tough to see where the wires connect to other wires.
CA Traveler
The Western States
Posted: 05/28/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
A wire tracer or toner device might help track the wire.
