RV.Net Open Roads Forum: Tow Vehicles: Tranny fluid change
Search only in Tow Vehicles
 > Tranny fluid change
Page of 7
azdryheat
Tucson, AZ
Posted: 05/28/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
ktmrfs
Portland, Oregon
Posted: 05/28/21 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
no real reason to drop the pan. Only time the pan needs to be dropped is if there is some reason to do internal transmission work. That's what's nice about the spin on filter.
I went to the deep pan on both my trucks, rather than the shallow pan the truck comes with. So the pan did come down for that. Being overly anal mostly.
BTW, on both my duramax trucks, I did a drain and fill with allison transynd rather than the GM fluid. Lasts longer, holds up better, and NAPA sells it at reasonable prices.
2011 Keystone Outback 295RE
azdryheat
Tucson, AZ
Posted: 05/28/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I dropped the pan to get all the oil out (about 1/2 quart was still in there) and to check for sludge (102,000 miles on the ODO).
I checked on the 295 oil and but went with Valvoline VI since it's done a great job so far and I didn't want to drive across town to NAPA.
Cummins12V98
on the road
Posted: 05/28/21 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
What about all the "OLD" ATF left in the converter???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Seon
Lake Camanche, CA
Posted: 05/28/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
You'll never get all the oil out, even by a professional shop
Next time someone drops their oil pan, best to install an oil pan drain plug. Much easier for the next oil change.
Cummins12V98
on the road
Posted: 05/28/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Too funny, the only vehicle I have not done a complete fluid exchange on is my current AISIN. It does have a factory pan drain plug as I would assume the Allison does.
Geo*Boy
Unknown
Posted: 05/28/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you can. Fill the transmission up, according to the dipstick, remove the return line from the oil cooler, install hose fitting, start truck, pump out a gallon, refill repeat until nice clean fluid appears.
FishOnOne
The Great State of Texas
Posted: 05/28/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty much what I found when I did my ATF along with a small amount of fine particles on the oil plan magnet.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
azdryheat
Tucson, AZ
Posted: 05/28/21 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
The Allison does come with a drain plug. I was just curious to see what was in the pan. Oh, and Allison does not recommend a fluid flush or exchange.
rhagfo
Portland, OR
Posted: 05/28/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Did this on both of my old Ford C6 transmissions. What I did was start and start adding as it drained the keep up as helper went through the gears slowly.
Page of 7
