RV.Net Open Roads Forum: Dinghy Towing: Death Wobble Continues ....
Search only in Dinghy Towing
 > Death Wobble Continues ....
ScottG
Bothell Wa.
Posted: 06/02/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
lryrob9301 wrote:
Harvard wrote:
Set caster to upper end of specified range.
This would be the proper repair except most vehicles today have non-adjustable Caster and Camber settings.
They have Castor adjustment but don't have camber adjustment.
Jarlaxle
New England
Posted: 06/02/21 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Many vehicles have neither.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ">
Current rig:
1992 International Genesis school bus conversion
Executive
Posted: 06/06/21 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
My research into the death wobble issue started when I experienced it with my Equinox. What I found was many thing 'can contribute' to a DW but the MOST OFTEN culprit was the power steering in the vehicles. In the Equinox case, it only occurred in the 4 cyl models. This was because it came with electric steering assist instead of hydraulic like the 6 cyl models. After my complaint to NHTSA, GM offered a solution. Instead of pulling the interior fuse, they switched it to the one under the hood. This allowed the power steering module to remain energized and functional while towing. Unfortunately, it also leaves all the other electrical items functional also. This means you should install a battery maintainer in your vehicle while towing to keep the battery charged. IMO, a minor inconvenience. While waiting for GM's 'fix' I installed an eye bolt through the floorboard just in front of the driver's seat. A bungee hooked to the eye bolt to the bottom of the steering wheel worked perfectly. However, GM's fix has cured the DW and I've had zero problems since using their new directions. As I understand it, Jeep has a similar power steering setup and the recall fix was simply a bypass cable for the steering module...hope this helps...Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
BruceMc
Oregon - Willamette Valley
Posted: 06/07/21 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I certainly believe it is the electric power steering that is the major contributor to DW. While we never towed out 2004 Malibu Maxx, it had a similar oddity at low speeds - the steering wheel would do a mild DW in my hands while the engine was at near idle, and making sharp turns as one would do in a parking lot. It was disconcerting, but never enough that would cause a problem. If we had towed that car, we may have encountered DW!
Our 2012 Canyon has hydraulic power steering, BTW. I was surprised it still had the old hydraulic when we purchased it.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
Ken C
Rapid City, SD, formerly SF Bay Area, Ca
Posted: 06/08/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
TC&Z wrote:
We are aware of the Death Wobble problem. We bought a used 2018 Jeep Cherokee and their special tow harness that prevents DW from occurring. Well despite our efforts DW still occurs when the Jeep hits a bump just right.
Given that we have done everything we are supposed to have to avoid DW, are there any other fixes or adjustments that can be made? Jeep is essentially new, only 15k miles so linkage is tight.
not have been in=
Thanks in advance...
Just a thought. Have you verified that the power steering is active after setting it up for towing - i.e. have you tried turning the steering wheel after inserting the fuse and turning on the switch for the harness installed. The steering should turn easily since the power steering is active. If not, it may not have been installed correctly. We have a 2015 Cherokee Trailhawk that we have towed approx 40K miles that has the harness installed and it corrected the problem.
Ken
2018 Newmar Dutchstar
Spartan K2
2015 Jeep Cherokee Trailhawk
TC&Z
Posted: 06/18/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
Is your tow bar dead level? Not pointing up to the MH?
We have a drop down so the tow bar is level. Thanks....
TC&Z
2007 Winn Voyage 38J, gas 8.1L engine
2018 Jeep Cherokee flat tow
TC&Z
Posted: 06/18/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Are you positive that the harness is working and powering the steering like it should?
To some of the other folks replying, great “general” suggestions as DW can be caused by many different things. But imo this issue is likely the power steering issue.
Bottom line, vehicles are beginning to get too smart to use for other purposes.
I flip the switch on the Jeep interior wiring harness, then open the hood and install the fuse. When I install the fuse I hear a faint "whine" so believe the power steering is being powered as intended....
Thanks
Skid Row Joe
Posted: 08/24/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis, I've got a 2017 Chevrolet Corvette zi bought new 4 years ago. Corvettes have the electric power steering as well. No problems even reported on Corvette Forum.
Ro"n"Joe
Full Timing
Posted: 08/31/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Dennis that it's related to electric power steering assist vehicles. Never saw a Corvette being towed and would think numbers are low compared to others commonly used toads. I haven't experienced it yet in my Grand Cherokee either at 14.5K miles of towing.
2020 Dutch Star 4328 on FL Chassis
2018 Grand Cherokee Limited
Ready Brute Elite Towbar & Road Master Wiring
hohenwald48
Nashville, TN
Posted: 09/07/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
The OP is asking about a new stock Jeep Cherokee. Not some highly modified and lifted and worn out Wrangler.
This is a known problem with newer Cherokee's and derivatives of the Cherokee. Jeep is aware of the problem and has designed a fix. If the fix has been installed and you still have the problem then the fix is not working for some reason.
Take it back to Jeep and make them resolve the issue. Don't start making modifications, changing the steering geometry or adding shade tree fixes like bungee cords. Take it back to the the vehicle manufacturer and have them fix it.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
