RV.Net Open Roads Forum: General RVing Issues: FRAMELESS WINDOWS?
 > FRAMELESS WINDOWS?
egarant
Mission Viejo CA
Posted: 05/29/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
As far as I can tell there are three kinds of RV windows out there …
The traditional sliding window, my favorite. When open you get what, about 40% open to the air?
The Doemetic push out window, a window NOT for grizzly country or for any kind of leave the window open while you sleep security. Plus you roll all the bugs attached to the screen down into the window when you let the screen drop. Those will never be an option ffor me.
Then the frameless windows…now my question is since those windows only go out a few inches, how much airflow are those windows allowing into the camper? Seems a bit restrictive to me.
Youe thoughts….
Cheer,
Mr. E
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
fj12ryder
Platte City, MO
Posted: 05/29/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Seems restrictive to me too, and it won't be straight through like the slide up windows. They look good, but I prefer the sliding windows. And I have read of a few cases where the windows have detached themselves from the trailer while going down the road.
Howard and Peggy
"Don't Panic"
Two Hands
California's Central Coast
Posted: 05/29/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
We have the frameless windows that crank out about four inches at the bottom. The air flow is terrible.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
2oldman
NM
Posted: 05/29/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
One of my sliders is sticking so bad I can hardly open it. Got any tips?
egarant
Mission Viejo CA
Posted: 05/29/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the screen and use a wet microfiber towell to clean the tracks really really good, That did it for me
3M does make a window slide lubricant that you might try.
bobsallyh
Livingston, TX.
Posted: 05/29/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman, try to clean the tracks that they slid in, then spray with heavy duty silicon and work back and forth.
Durb
NW
Posted: 05/29/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the sliding windows and now Hehr frameless. The sliders probably offer more ventilation but I can turn on the bathroom fantastic fan and create a pretty good breeze. Need more ventilation, open the door. The frameless offers the ability to open when raining. Another point, moot for some, the frameless windows make it extraordinarily easy to buff off water spots. Where I live, that is a big deal.
SDcampowneroperator
South Dakota
Posted: 05/29/21 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Frameless are easy to clean , attractive, dont open much. Road debris has broken 3 of ours, in over 50k miles.
tempered glass cant take a hit on the exposed edge. Fixing at a local shop was much cheaper than a replacement from Heil. Ordered glass from a shop, replaced it our selves. small job.
We like them.
StirCrazy
Kamloops, BC, Canada
Posted: 05/30/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I have framless in the 5th wheel, I find you get a fair amount of flow but you have to open a bunch up. the slide has normal slide windows so I can open thoes also.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Gdetrailer
PA
Posted: 05/30/21 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than typical liquid lubricants try using candle wax.
Clean the track well with a cloth then rub a candle over the track, may take a couple of times but it should eventually stop getting stuck..
Candle wax since it is dry does not attract or hold dirt/dust and cleans easily.
Candle wax also works great on sticking zippers (rub candle over the length of the zipper a couple of times and zipper should move easily after that), very useful for driving long wood screws (rub wax on the screw threads then drive home)..
Most liquid lubricants attract and hold dirt and dust or evaporate over time.
