RV.Net Open Roads Forum: Plug or unplug that is the question
 > Plug or unplug that is the question
StirCrazy
Kamloops, BC, Canada
Posted: 05/30/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I never unhook the 7 pin weather I am hooked up to shore power or not. the solar charger is always going and I have no conection between the battery in the camper and the 7 pin so no need.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pitch
NY
Posted: 05/31/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I always unplug, if just for an overnite. I also drop the stabilizers. Don't know or care what could go wrong,just know that it can't if there is no connection.
RCMAN46
NorthWest
Posted: 05/31/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
"I can't think of any risk in disconnecting, except for maybe forgetting to reconnect when you leave, but you'll figure that out pretty quickly when you check your mirrors and don't see your running lights on." X2.
I also lay the 7way connector on the bed rail where it can be seen in the rear view mirror. But if you check your trailer brakes and lights it is unlikely you would forget to connect the 7way.
JimK-NY
NY
Posted: 05/31/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
I never realized trailers had to be disconnected and I certainly don't understand why. I have a truck camper. The 7 way is always connected to my truck.
beergardens
Calgary, Alberta
Posted: 05/31/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
The charge wire from my truck is always hot, so yes, I unplug. If that circuit drew power through a relay, as many newer trucks do, I’d probably leave it plugged in. I’m not worried about forgetting to plug it back in before driving away, as I’ve made it part of the routine to put the flashers on and do a quick check of the rear of the trailer to check or light, each morning before driving away.
wnjj
Cornelius, Oregon
Posted: 05/31/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Jframpey wrote:
I disconnect- Chevrolet stays hot with ignition switch off (at least 2008 Silverado). Why take a chance of draining my vehicle battery? What if the converter quits, power outage, surge?
If you’re going by risk, there’s a greater chance a pin will break off in the 7-way connector when you go to plug it in than a power issue affecting your truck. Even if the shore power failed, you’d have to run enough 12v loads to drain your trailer and truck batteries.
In our case it’s a truck camper and there is no option to unplug until it’s partially lifted up.
