RV.Net Open Roads Forum: Tech Issues: NorCal Fridge wont run on AC
 > NorCal Fridge wont run on AC
jonaz
Posted: 05/29/21 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Everyone,
Just bought a new 2021 Coachman Catalina and I am waiting to get it back in the shop for some warranty work.
In the meantime, it has a Norcal fridge, with only one button on the front. The Fridge runs on propane, but it does not get cold on AC. The fridge light opens when I open the door so its getting AC. I have turned the Fridge off, with AC plugged in and then turned it back on numerous times, and still it does not get cold. A red light will eventually come on, telling me that there is an issue.
Any suggestions on what to look for? It's going to be another 3 weeks before I can take it in.
Thanks in advance,
Jonathan
[blue]2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears) Prodigy brake controller,Weight Distribution Hitch 2021 Coachman Catalina 263BHSCK
Note: Due to invalid formatting, all formatting has been ignored.
Ed_Gee
Central Oregon coast
Posted: 05/29/21 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Refrigerator Model number would be helpful ...
Is that really a Norcal.... or is it actually a Norcold ?
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
2edgesword
New York
Posted: 05/29/21 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think the fact the interior frig light comes on means you're getting AC. I believe the light runs off DC and would come on whether or not you're getting AC power to the frig.
jonaz
Posted: 05/29/21 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
Norcold. Thanks Ed. Trying to find a model number.
Good point about fridge light 2edgesword.
agwill
enosburg falls, vt
Posted: 05/30/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
It will take 24 hours to get cold. How long have you waited? Is it plugged in in back? Is there 110 volts at plug? First places to check.
al
Scottiemom
Posted: 05/30/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 with a Dometic fridge. It quit running on electric. That almost never happens. . . it's usually the other way around. Works great on gas, though. So I took it to the Amish and they tested everything. The fridge actually does run on electric, but not through the plug it's plugged into. So I had my electrical engineer friend put in a new outlet. The old outlet was one of the really cheap trailer receptacles that are a press fit and the wires were just not making good contact. Now it works great. My friend charged me nothing for labor and the parts were $1.87.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
Ed_Gee
Posted: 05/30/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
The Model number is likely on a sticker inside the fridge - mine is on right side wall lower down the side....
jonaz
Posted: 05/30/21 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the model number was on the side, thank you.
Norcold Model N7VLW6
wnjj
Cornelius, Oregon
Posted: 05/31/21 01:21am Link  |  Quote  |  Print  |  Notify Moderator
Remove the outside cover and you’ll see that the fridge just plugs into a receptacle. Plug something else in there to confirm the receptacle has power. If it doesn’t, check for a tripped GFCI there or elsewhere. Check all of the 120V breakers.
jonaz
Posted: 05/31/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
OK, I feel like an idiot. I removed the cover and realized that the fridge was not plugged into the AC receptacle. I kept looking for the plug but it was run way up on top and took a little while before I was able to get my hand around the end and bring it back down to get plugged in. Thank you so much for all your help.
* This post was edited 05/31/21 10:28am by jonaz *
