RV.Net Open Roads Forum: Class A Motorhomes: Leveling jacks alarm
 > Leveling jacks alarm
MrWizard
Traveling
Posted: 06/04/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
To PROPERLY check the reservoir
You must be parked on level ground, and level...without using any leveling aids, then add fluid until the alarm stops or its full and you can't add more, if the alarm won't stop, the float switch is bad, on mine you have to take it apart to replace the float switch
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
