RV.Net Open Roads Forum: Class C Motorhomes: Worn suspension
 > Worn suspension
EMD360
Arvada, CO
Posted: 05/30/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Today someone told me the suspension on our old RV might need work. I was surprised because normally in a car when the suspension is going the ride really changes and there are noises. I had the RV on the road just yesterday and didn’t notice any problems. But it does have over 54,000 miles on it. I also don’t see any uneven tire wear or noticeable sagging. The guy said the right side is lower but I really could not tell. Is it common to need new leaf springs?
I had the rear brakes fixed last year at a truck shop and they didn’t mention a problem with the suspension. How can I tell if it’s really a problem?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
tobydad
MA
Posted: 05/31/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
The key word in your 1st sentence is "might". If you have not experienced any noticeable change, then there probably isn't any. You can always use a tape measure on each rear corner to the ground to determine any sagging. If you have air bags in the rear suspension, then check for leaks or check that the pressure is equal in each air bag.
Gjac
Milford, CT
Posted: 05/31/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
To see if one side is sagging park the MH in a flat parking lot and measure the ride height front and back at the 4 corners, compare those measurements to what the chassis manual says. Is your front end IFS or straight axle?
EYEMLOST
See Above
Posted: 05/31/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Are the shocks factory originals?
Does the RV's rear live at maximum axle weight all the time?
1998 FWC Grandby
1994 Ford Bronco 5.0 XL 4X4
Sky's ORD 6" Lift / Sterling 10.25 Dually 5.13 Gear Detroit Locker / '99.5 Front F-350 Leaf Springs at Rear / HMMWVtires
Gary45
Oshawa, Ontario, Canada
Posted: 05/31/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
You can visually inspect the leaf springs, normally one or two leafs can crack/break and you will not feel anything.
ferndaleflyer
everywhere
Posted: 05/31/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Good luck checking all 4 corners. To many cargo things affect that, even fuel, water, and waste tanks. 54,000 is nothing.
Quartzsite, AZ
Posted: 05/31/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
If you want to do something, new shocks might be in order, but it seems you were happy before this unsolicited “advice” and having no issues.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bobndot
Posted: 05/31/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
If you cant see where its sagging then how much could it really be sagging ?
I would get a second then third opinion from mechanics who can actually look it at and who know what they are looking at.
EMD360
Arvada, CO
Posted: 05/31/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
It’s been raining so I haven’t gotten under it. The answer to living at full axle weight is probably. It’s been years since I weight it fully loaded. But my specs say if all the tanks are full I have 239 lbs carrying capacity. That’s maybe one adult and a kid. As I recall I wasn’t over on my four corners weight fully loaded except for passengers. I just stopped worrying about it. Maybe it will show up in a suspension issue. I’m going to check it out.
Posted: 06/01/21 12:29am Link  |  Quote  |  Print  |  Notify Moderator
^That really makes no sense if you’re almost overloaded with just tanks full.
Check out your springs. And as said above, you may just be worrying about nothing. But you won’t know unless you check.
2017 Heartland Torque T29
 > Worn suspension
