RV.Net Open Roads Forum: Truck Campers: Patch small hole in aluminum siding
 > Patch small hole in aluminum siding
silverbullet555
Boise
Posted: 05/30/21 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy again,
I noticed I have a small hole in the aluminum siding where there was a slight impact. I don't know if I caused it or if it was there when we bought the camper a year ago. I'd like to seal it. Is there a recommended product and method?
I have most common sealers including some RV specific ones for vinyl roofs.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
Kayteg1
California > Nevada
Posted: 05/30/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Get 1 of those stickers.
Sagebrush
Jacksonville AL
Posted: 05/30/21 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
For small holes I just use white butyl seal tape if the color works, I push it in with my fingers. I always keep a roll of white butyl onboard. Less messy than caulk on small wall stuff. If its a colored area maybe use a clear flexible caulk like Pro Flex Chrystal Clear etc.
DougE
New Braunfels, Texas USA
Posted: 05/31/21 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Get a fiberglass repair kit from the local auto supply. It goes on quite transparent and will be barely noticible.
Currently Between RVs
silverbullet555
Boise
Posted: 05/31/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Good idea. I have some of that. If I had a tube of 3M 5200 that was open, I'd go that route.
wanderingaimlessly
Buggs Island lake
Posted: 05/31/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
If its just a pin hole, drill it to avoid a crack starting and then put a screw in it.
jimh425
Western MT
Posted: 05/31/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Eternabond tape will stick almost anywhere. It’s also available in different colors. That would be my fix.
bgum
South Louisiana
Posted: 05/31/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Bondo aluminum and it can be sanded and painted. Are you sure that the hole is not due to electrolysis?
thedavidzoo
Tucson, AZ
Posted: 05/31/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Marine-Tex epoxy maybe
I have used this stuff several times to patch small holes, mostly fiberglass. You can mix up just a tiny amount.
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
opnspaces
San Diego Ca
Posted: 05/31/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Put on the Butyl tape and use a razor blade to trim it flush. Then put a sticker over the repair.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
