RV.Net Open Roads Forum: General RVing Issues: Bluetooth Battery Monitor
 > Bluetooth Battery Monitor
SHRED
California
Posted: 05/31/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
For ease of installation I'm looking for input on Bluetooth battery monitors.
Any that you are satisfied with.
Thanks.
2021 27' Lazy Daze mid bath
2oldman
NM
Posted: 05/31/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Hard to beat the Victron BMV-700. It does require a shunt on the negative side, and a + power supply. Not difficult.
Post may get moved to tech issues or technology.
* This post was edited 05/31/21 11:03am by 2oldman *
FWC
The Wilderness
Posted: 05/31/21 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
If you just want bluetooth (ie no hardware display) then the Victron Smartshunt is the ticket. If you want a display as well as bluetooth then the Victron BMV-712 is the way to go.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 05/31/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Doubt after a couple of trips you’ll be monitoring all that often. I opted for a $42, 500 amp monitor for my 600AH of DIY Lithium batteries. Once the BMS stopped charging them I set the AH to 900AH... it keeps track of usage, %, charge/discharge amps, and voltage...all the info I need. Helped that the display was easy to locate in the BR.
Monitor
https://www.amazon.com/CAMWAY-Voltmeter-Backlight-Waterproof-Motorhome/dp/B088RG27LS/ref=mp_s_a_1_10?dchild=1&keywords=aili+500a+battery+monitor&qid=1622487745&sprefix=aili+&sr=8-10
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
SHRED
California
Posted: 05/31/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at this one also.
BALMAR MONITOR
2oldman
NM
Posted: 05/31/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Be careful going cheaper.
dodge guy
Bartlett IL
Posted: 05/31/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
This is the one I have my eye in when I go solar.
Battery monitor
Will from DIY solar with Will Prouse gave it a pretty good review as did most buyers on Amazon.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
ronbiel
AL
Posted: 06/01/21 02:42am Link  |  Quote  |  Print  |  Notify Moderator
I love my Victron BMV-712. Worth the cost.
dodge guy
Bartlett IL
Posted: 06/01/21 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Battery monitor
Sorry, this is not a Bluetooth unit, just seen the title to the post again. But if the Bluetooth is anything like the bluetooth in my Hughes Watchdog protector you need to be within 10ft of it. Makes it being Bluetooth kind of worthless.
2oldman
NM
Posted: 06/01/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Yep. Like having to go sit near the wifi antenna to get anything done.
The one complaint I have about my Victron is the warning buzzer. It only seems to work at the physical unit itself, which is in the battery compartment where I can't hear it.
