RV.Net Open Roads Forum: Tow Vehicles: Tuner like “5 Star Tune “
Search only in Tow Vehicles
 > Tuner like “5 Star Tune “
Rwake901
Central, Illinois
Posted: 05/31/21 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 3500 Silverado 6.0 gas. Has anyone used a tuner like a “5 star tune “ ? I was wondering if or how they work before I purchase one and which brand I should buy? Thanks
dodge guy
Bartlett IL
Posted: 05/31/21 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Check out Black Bear tuning. They specialize in GM motors as 5 star specializes in Fords.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
nickthehunter
Southgate, MI
Posted: 05/31/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
What is it you want the tuner to do for you?
ShinerBock
LVTX
Posted: 06/01/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I had a 5-star tune in my old Ecoboost F150 and loved it. I have a few friends who had their tunes in the 6.8L V10 motorhomes and they loved it as well. You will notice more of a difference in power in a turbocharged engine than you will in a N/A.
* This post was edited 06/02/21 07:47am by ShinerBock *
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
Rwake901
Central, Illinois
Posted: 06/01/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Hopefully more torque and HP. When towing at 65 mph I don’t want it shifting down on every little rise in the road. It actually does a pretty good job but it would be a lot better and less shifting with a little more HP. Thanks
dodge guy
Bartlett IL
Posted: 06/01/21 08:48am Link  |  Quote  |  Print  |  Notify Moderator
You won’t get a significant increase in HP and TQ but a good tuner will allow you to use the power you have much more efficiently. The factory tuning with the drive by wire is so intrusive it’s ridiculous! My 2012 class A V-10 has drive by wire and it was crazy how underpowered it felt when driving! The tuner made a huge difference in both the trans tuning and performance.
LanceRKeys
Amarillo, TX
Posted: 06/01/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could manually downshift and just run one gear lower all the time to avoid downshifting? Sometimes running at a slightly higher or lower speed may help as well.
philh
Belleville MI
Posted: 06/01/21 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
OEM's calibrate for variety of conditions. Tuners take out the "safety" tolerance. Some do a good job, others, not so much. I knew of a guy who did mobile tuning. People LOVED his results, but just about every engine he tuned, eventually grenaded.
I've have and had tuners, but won't put one on the truck I use for towing.
WRT shifting, transmission is looking to put the transmission in the correct gear for the conditions.
mkirsch
Rochester, NY
Posted: 06/02/21 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Tuners won't do anything for engine output on a normally aspirated gas engine. That's already been maximized by the manufacturer.
All tuners do is give your subconscious a lead foot so you stomp on the pedal harder, say, "YEAH! I HAAAAAAVE THE POWERRRRRR!" to yourself, then find out three days later that nothing really changed and there's a hole in your wallet where several hundred dollars used to be.
Devo the dog
Moved out of crazy California
Posted: 06/02/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Not true for regular vehicles.
Performance can be measured and the tunes increase HP and torque.
* This post was edited 06/02/21 10:02am by Devo the dog *
The dodge fan boys hate the dodge/ram dealerships. Now that I have owned a Mexican Fiat Oui-Oui (La fiat wee-wee), I understand why.
The only thing more incompetent than Ram is Bye-don and his supporters.
