RV.Net Open Roads Forum: Class A Motorhomes: Slide toppers
Seabass69
Posted: 05/31/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Looking to replace the fabric on my slide toppers? WHat is the process or where do I start? I would like the exact fit ....
CA Traveler
The Western States
Posted: 05/31/21 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Find instructions for your mfg. I extended the slide, locked the roller in place, retract slide some, remove screws in roof channel, remove roller with topper from the roof channel, replaced the topper on the ground and reinstalled. 2 people and ladders were needed. 4 hours for 4 toppers.
2014 Grand Cherokee Overland
Bob
Seabass69
Posted: 05/31/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I should have
worded it better, where should I look at buying them from?
CA Traveler
The Western States
Posted: 05/31/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't want another CareLess designed to outlast the warranty topper so ordered from http://stonevos.com/index.php/about-us/.
* This post was edited 05/31/21 09:30pm by CA Traveler *
rgatijnet1
Posted: 06/01/21 04:58am Link  |  Quote  |  Print  |  Notify Moderator
I took mine to a marine canvas shop. They were able to match the fabric and make exact replacements.
Posted: 06/01/21 05:24am Link  |  Quote  |  Print  |  Notify Moderator
You might not need to replace it.. Often there is enough fabric on the roll you can simply reverse it
Extend the slide. Pin the roller (You will need to find instructions for that) and bring slide back in a bit, You can then dismount the roller. On the body end you may have to remove a screw or two and "Spread" the channel a bit. then slide the thing out or pull the rib and pull it out (id' slide rib and all. or to be more precise I did) unroll fabric. but body end in roller. put roller end in body and reassemble. If there is enough fabric, if not ... take old fabric to RV store or other (Canvas tarp) store and they can provide replacement.
William B
On the road
Posted: 06/01/21 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Stone Vos they make the best quality awning fabrics, great service, incredible warranty, excellent product.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
dalenoel
S.E. Michigan
Posted: 06/01/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Stone Vos in Brooksville, FL is the best and reliable source.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
corgidad
Posted: 06/01/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I will also recommend Stone Vos, Just received my new slide toppers and awning fabric from them. The quality is above and beyond any other fabric I have ever used. The customer service is second to none. Give Ingrid a calll you will not be sorry.
Seabass69
Posted: 06/01/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone
