RV.Net Open Roads Forum: Tech Issues: Filling of Propane tank
 > Filling of Propane tank
craig7h
Branson MO area
Posted: 06/01/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Does it make a difference if you get your propane filled at 8900 ft or 1000 ft. Reason I ask is right now I am at 8900 ft and could top off the onboard tank. Or am I better off to wait until I get to a lesser elevation? Is it a quantity thing.
Itasca Meridian SE 36g
Road Master Tow Dolly
valhalla360
No paticular place.
Posted: 06/01/21 06:20am Link  |  Quote  |  Print  |  Notify Moderator
The "L" in LPG is for liquid. They are putting a liquid in the tank.
There may be a difference but so small, you likely couldn't measure it.
Temperature and altitude can mess with the appliances that use the LPG. The propane evaporates and passes thru the piping systems as a gas. Here altitude can have an impact as there is less oxygen available.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Old-Biscuit
Verde Valley
Posted: 06/01/21 10:50am Link  |  Quote  |  Print  |  Notify Moderator
tank is a closed pressure vessel....atmospheric pressure has no affect on the internal pressure.
**Can affect the fuel/air ratio AT the appliance burners
tank is under 100#-250# depending on the Temperature of the ambient air as heat can cause more or less liquid to vapor action
Top off as needed wherever you are.
They will pump liquid into tank until:
Fix Gauge spews liquid (bleed valve cracked open during filling)
OPD shuts off flow
**Both are set for 80% tank capacity as that is FULL
US NAVY------USS Decatur DDG31
Posted: 06/01/21 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what sparked the question...maybe be more specific as to your concerns.
(FWIW, there aren't any, based on altitude)
2017 Heartland Torque T29
dougrainer
Carrolton, Texas
Posted: 06/01/21 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Correct. What DOES affect DOT tanks is HEAT. Fill a DOT 20# at Ambient 40 degrees and slightly overfill(it can be done even with Auto shut off) and take that unused tank to 100 degree ambient and odds are the Safety blow off valve will release. A correctly filled DOT may still have the same problem when you fill at a lower temp(below 50 degrees) and then go to a higher degree area(over 90 degrees), which is easy to do, if you do not use that tank. Fill in the winter and not use and then take it out in the hot summer. This used to be more of a problem years ago(DOT tanks had no auto shut off)when unqualified/Ignorant LP fillers would attempt to "top off" the DOT fill and not fill by weight. Now, with Auto shut off fill valves this is a rare occurance. Doug
time2roll
Posted: 06/01/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Less chance of getting any butane mix at 8900 feet.
675w Solar pictures back up
Dutch_12078
Winters south, summers north
Posted: 06/01/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
LPG (commercial propane) typically contains 90%+ propane and less than 10% butane.
Dutch
2001 GBM Landau 34' Class A
C Schomer
Pueblo West, Co.
Posted: 06/01/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it isn't the person who's doing the filling that's shorting you? I get tanks filled at Costco, Glendale Az. And they short all of them 2 pounds. I get them back to Co. And I top them, to the OPD float valve, no problem.
LP and NG etc. automatically derate at higher elevation because the density is lowered. Its either Charles or Boyles law. It been too long since college! The formula is very simple. It has to do with old and new volumes and pressures. Craig
BarabooBob
Baraboo, WI
Posted: 06/01/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I get my tanks filled t place that charges me my the gallon. They set the tank on a scale to tell when the tank is at max full and charge me for the gallons to top off.
Most of the places around here that exchange tanks are currently selling 15 pounds of propane in the tanks. They tell you on the sign that is posted that you are paying for 15 pounds so it is not fraud. You just have to read the sign.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
red31
Dallas
Posted: 06/01/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
craig7h, which ever is colder!
