RV.Net Open Roads Forum: Towing: Falcon shocks for towing. Any good?
Search only in Towing
Open Roads Forum  >  Towing
 > Falcon shocks for towing. Any good?
goducks10
There
Posted: 06/05/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Whats your tongue weight and what hitch are you using? You say you're maxed and can't get the front end down anymore. That says your WDH is too weak.
FYI air bags won't help the front of the truck.
Don't worry about the rear of the truck. It is what it is when you get the front set right.
Floating fronts mean you don't have the WDH cranked up enough. Are you needing to raise the rear of the truck to hitch up?
Posted: 06/07/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
speediq99 wrote:
I agree there are a couple of things to try before new shocks. The tires is the only one I have not tried yet.
MC
Pump them tires up and try it, like I mentioned in your other thread. Free test.
You can spend all day and a weeks pay dialing it in "perfect" and then it wont be perfect...
2017 Heartland Torque T29
speediq99
Arizona
Posted: 06/07/21 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Tongue weight is 750-850
Hitch is 10k equalizer
Trailer weights 6300 dry, loaded 7500
I don't have to raise truck to hitch but I do need to do it to load the bars.
WD has 7 washers on it and L brackets are all the way up. There is a lot of tension on the bars.
MC
* This post was edited 06/07/21 11:24pm by speediq99 *
goducks10
There
Posted: 06/08/21 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
MC
Really hard to find fault with what you have and are using. 7 washers is a lot. BTDT.
