RV.Net Open Roads Forum: Towing: Falcon shocks for towing. Any good?
Search only in Towing
Open Roads Forum  >  Towing
 > Falcon shocks for towing. Any good?
speediq99
Arizona
Posted: 06/01/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I am thinking of adding the Falcon adjustable Tow Shocks to my 2021 F150 Powerboost crewcab.
I tow a 7400lbs trailer. The problems I am trying to solve are slow bounce recovery when driving on roads with small bumps and a little bit of front end floating when driving in 20mph winds. I use an equimizer and it is set properly to distribute weight front and back. The truck just bounces and floats a little in windy and road imperfections.
Would the Falcon shocks help?
Would adjustable airbags do better?
They are priced about the same. I just need to make a choice if they both make any difference at all.
???????MC
Posted: 06/01/21 11:44am Link  |  Quote  |  Print  |  Notify Moderator
I'll say not enough to cover the cost of the shocks. Plus you would need to enquire how they are valved. In my experience, most off the shelf high $ remote res/rebuildable shocks are designed for quick compliant valving on small bumps and big resistance on ground out type bumps. Aka high speed off road driving.
That said, a properly valved set of big shocks could help.
I just don't see needing to put new shocks on a brand new top of the line pickup to tow a modest load.
2017 Heartland Torque T29
Monterey, California
Posted: 06/01/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Shocks won't fix frontend floating. You need to shift more weight.
Diamond c
West ky
Posted: 06/01/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I would always choose air bags over shocks if you can afford them.
Posted: 06/01/21 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
It's not an either/or type of scenario. They perform 2 totally different functions.
BenK
SF BayArea
Posted: 06/01/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Grit…you just described the Edelbrock Performer IAS mono shocke that was the first to have inertia valved shocks.
Had a set and confirm that in slow going…VERy PAINFUL but wonder when driving like Parnell Jones in the desert.
They have the valves on the rod piston and why hey are mounted upside down (rod down). As that is the only way to sense rate of change quickly.
They also leak and think because of the rod down mounting orientation. Switched to KYb MonoMax and they are best for all round usage, IMHO. Bilstein’s don’t do it for me, but many, many swear by them.
Might go back to iAS’s after rebuilding the Suburban to be mainly a pavement vehicle.
Also agre with Grit and the OP should look else where for a fix. Though shocks are cheap enough to try.
-Ben Picture of my rig
mkirsch
Rochester, NY
Posted: 06/02/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
I would contest that you have your WD set up properly if your front end is floating, at all, ever.
Probably set up to that new "50% of unloaded height" spec they put out, right? Try putting a little more weight on the front, like 75%. Cheaper than the shocks.
Posted: 06/02/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I saw $1300 for a set. Not zactly cheap, but...
OP, when you say slow bump recovery, do you mean bounces too many times before settling down, or doesn't rebound in time before the next bump?
If the first, yes stiffer/heavy damping on rebound will keep the bouncing down. If the latter, you're towing a trailer, not running the Baja, and expectations may be a bit much.
Front end "floating", yup you have a heavy trailer on the back of a F150. I can't imagine its bad at all, especially with a wdh doing any sizeable amount of work.
To the floating, yes stiffening up the rear suspension can/will help with both conditions. But my guess is you may not have alot of towing experience and are looking to perfect "your" experience.
speediq99
Arizona
Posted: 06/02/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I am at 50% already. The front end on this truck is pretty interesting. No trailer it sits at 37 inches. Trailer on, no equalizer, it goes to 37 1/2. Getting to 37 1/4 is nearly impossible but at least I am neither below 37 or above 37 1/2. The rear end goes from 39 1/2 to 37 so getting to 50% is easier. It looks like the rear is much softer than the front.
I wish I could try 75% in front but it looks like I may be maxed out and unable to add washers or raise L brackets and getting to 75% seems hard without messing the rear.
I read a little about 10 ply tires.. The truck comes with 6 ply and most people recommend 6 ply as a good compromise. I was wondering if the ride quality when not towing would get impacted too much with 10 ply. When the truck bounces, it certainly feels like the tires are flexing but it could be the springs/shocks.
I agree there are a couple of things to try before new shocks. The tires is the only one I have not tried yet.
MC
Posted: 06/02/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Load range E tires will take some flex of bounce out of the equation. And they won't ride any different that Load range C tires, unloaded, if you adjust the pressure properly.
Based on your responses and questions, though, these "issues" sound more like your perception and not actual towing problems.
