RV.Net Open Roads Forum: Tech Issues: Issue with tail lights on 5th wheel
 > Issue with tail lights on 5th wheel
dpgllg
South West Pennsylvania
Posted: 06/02/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
While returning home last week I had a blowout on my 5th wheel that damaged the wiring passing through the wheel well. The wiring was spliced and I have all lights except running lights and tail lights (turn brake 4way all work).
I have a 2013 Chevy 2500HD diesel and have checked and replaced the fuse (#25) under the hood but still no running or tail lights.
What do I need to check next to trouble shoot this issue?
Thanks!
Dave
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
QCMan
Independent Republic of Horry
Posted: 06/02/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Check to make sure that when the wires got broken a connection up or downstream didn't get pulled out.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
ICamel
Oregon
Posted: 06/02/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Check for fuses on the underside of you 5'r pin box.
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 06/02/21 11:56am Link  |  Quote  |  Print  |  Notify Moderator
No test light or voltmeter?
RCMAN46
NorthWest
Posted: 06/02/21 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I believe the fuse on the truck you are looking for is in the fuse box on the side of the dash on left side between dash and door.
dpgllg
Posted: 06/03/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
OP Here
I tested the 7 pin plug on my truck and have power to the plug. It looks like I will have to drop my underbelly and trace the wire to find the issue.
