RV.Net Open Roads Forum: Tech Issues: Dometic portable fridge/freezer
 > Dometic portable fridge/freezer
cptqueeg
Idaho
Posted: 06/28/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
My buddy raves about his. It's in a FWC TC shell model.
Almot
out there
Posted: 06/28/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
dieseltruckdriver wrote:
We just bought one of these based on a review from Haylett RVs Youtube review.
We bought it to haul some meat across the state, and right now we are testing it as a beer cooler.
After 1 week, we like it.
These Chinese boxes come under several different names, all looking alike: Alpicool, Bodega, Costway etc: Alpicool. Almost like yours, isn't it...
All have so-so efficiency, poor insulation, the hollow lid is particularly bad, I had to add insulation on it. Some have LG compressor, those are quieter but I doubt they are more efficient.
I have a 50L dual-zone Alpicool. 45 AH per 24 hours in dual mode, with both freezer and fridge bins at their respective temps. 60 AH when it's really hot, at 90+ it's drawing 4-5A, cycling almost nonstop. People are raving about how energy-efficient are their $$$ units from Dometic, Arb and Engel, 5 days on a single 100AH Li battery, but when you need to freeze, the draw increases 2-fold. Can't trick the thermodynamics laws.
mr_andyj
Georgia
Posted: 06/29/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Its the greatest thing ever!
Do not return it.
Run it for a few days just to make sure it is not defective, but otherwise it is perfect.
You are asking on an RV forum, you should instead ask "overlanders". RVers typically have the absorption fridges in their campers so they will tell you how great those are having never owned or used a compressor fridge.
The dual zone is so much better than the single zones, for me anyway. Having a freezer is very important for long trips, and having a big freezer like you do is way better than those small ones.
These use very little DC power and can run off your car for an afternoon without draining the starting battery, but don't do this, you need to give it its own power source. When used with at least 200 watts of solar and a couple of deep cycle batteries , or lithium power source, you have off-grid endless refrigeration.
I have the 200 solar and two GC batteries (5 yrs old now) and this seems minimal for keeping fridge and freezer going with little other power draws on camper. I wish I had 300-400w solar now. Next batteries will be lithium power source. By morning Im below 12 volts, but during the day in the sun the batts stay at 13.8 from the solar. Not running the freezer uses a LOT less power, so as soon as the freezer is empty it gets turned off, leaving only the fridge side on.
The only issue is where to locate the chest as your RV is made for a front-opening fridge, not a top-opening...
* for those browsing here, know that not all dual-zone brands/models are able to just turn one side off, or alternate fridge/freezer duties. Read the details. I specifically bought one that I can turn off one side / do anything with either side I need to. Not all fridges at the time could do this
* This post was last edited 06/29/21 07:19pm by mr_andyj *   View edit history
obiwancanoli
Napa
Posted: 06/29/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Actually, the plan was to store in in one of the storage bays, AFTER I install a sliding tray to house it There's a plug on the wall behind where it will sit.
Almot
out there
Posted: 06/29/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Dual zone is definitely more convenient than a single zone. When freezer bin is empty, you can set the freezer bin to the same 4F and remove the divider between the fridge and freezer bin (at least, In Alpicool I can remove it). Yes, 200W solar will run 50L box indefinitely - including the freezer bin, if most days are sunny. Otherwise it's 2 AH per hour, so running it off the starter battery for a few hours is no big deal, but don't do it all day.
obiwancanoli
Napa
Posted: 07/02/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Well, after having the unit plugged in for 3 days, it has easily maintained the 5 degree temp I set for both sides/zones. While only put frozen food in one side, I wanted to see how both would do. Yes, I can turn off one side or the other, but it looks like this one's gonna make me glad I picked it up... on sale!
obiwancanoli
Napa
Posted: 08/28/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, the 75DZ is doing great, and the sliding tray I ordered just arrived today. Need to install the tray, but nothing came with it, so got to get over to Home Depot for the right screws. I assume the flooring in the bay is wood, and not especially thick... maybe 3/4"... but should I also include lock washers?
jaycocreek
Idaho
Posted: 08/28/21 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Dometic CFX coolers are the Cadillac of portable compressor refer/freezers with all the bells and whistles..Dometic/Engel and ARB are the choices of the overlanders and off grid users that need a tough reliable refer/freezer that doesn't use to much power..
The compressor is the key as well as insulation for them to use less power and last longer..Dometic used to use Danfoss compressors and Engels use a Sawafuji Swing Motor which is made in Japan...Dometic now uses their own VMSO3 compressor which there engineers say there goal is 1 amp hour per hour or 24 amp hours a day..
I have two portable compressor single zone cooler,an Engel and a Iceco 3-1 icooler(Danfoss compressor) that looks like a Yetti with a danfoss compressor..lol..The Engel is by far the better for power usage..I am testing the Danfoss model now..
Enjoy your new Dometic 75DZ and remember,freeze mode uses almost double the power as refer mode..Tons of video's on youtube showing the actual consumption of most compressor fridges..
