RV.Net Open Roads Forum: sewer line upgrade - need to replace cap and sewer hose
 > sewer line upgrade - need to replace cap and sewer hose
rvshrinker
Beautiful Pacific Northwest
Posted: 06/02/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
The cap with the bayonet clips needs replacing, also my stinky slinky has a hole. Is there a recommended ‘system’ for all this? My slinky lasted 3 years before developing 2 holes. I guess that’s just the expected lifespan. I know some have a clear elbow they hook up to the sewer line, I’m not sure I really want to see more than I need to!
so: stinky slinky plus sewer cap upgrade, let me know your thoughts.
Dutch_12078
Winters south, summers north
Posted: 06/02/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
This cap will let you see if there's been any leakage before you remove it:
Camco Clear Sewer Cap
This is the hose I use and have found to be quite durable:
Camco RhinoFLEX 15ft RV Sewer Hose Kit
Dutch
2001 GBM Landau 34' Class A
agesilaus
North Florida
Posted: 06/02/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I'm trying some sealant spray on one of our hoses that leaked from day one. I'll let everyone know if it works. I connected our cap with a length of 1/16th inch cable that is too short to let the cap drag if forgotten.
As for brands I favor Rhino right now because of the way it collapses and stays collapsed.
For caps whatever appeals to you, Camco is the most common.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
IAMICHABOD
Sunny So Cal
Posted: 06/02/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Dutch has good Ideas and I use the Rhino brand too.But I like a Clear Elbow connected to it so I can see if the tank is clean after dump and rinse
As for the cap I like the ones with a handle,much easier to use with these old hands,Like this one it also comes in clear. the small cap is useful to drain anything into the hose doing away with that surprise when opening the large cap.
Former El Monte RV Rental
Buying A Rental Class C
JimR 1
Custer South Dakota
Posted: 06/02/21 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto on the RinoFlex
JimR
QCMan
Independent Republic of Horry
Posted: 06/02/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Where do you store your hose? If you keep it in the bumper it will not matter what hose you get as the rust inside will wear holes in any hose. Get a fencepost with caps or a round plastic sewer hose storage pipe. A good cap is a clear one with a garden hose fitting on it so if there is any leakage you can control the release of it. Not fun but better than pulling the 3" cap with fluids behind it.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
agesilaus
North Florida
Posted: 06/02/21 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
My bumper is aluminum
rvshrinker
Posted: 06/03/21 01:04am Link  |  Quote  |  Print  |  Notify Moderator
thank you everyone for all the ideas and tips
Posted: 06/03/21 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Caps are mostly generic. Any RV store. Wal*mart, and many hardwares have 'em
Hose. I like the Tetford I think it's the Sentenal now days but it's a heavy duty
Drain master is of course. the best
