RV.Net Open Roads Forum: Tech Issues: Black Tank Dump Valve
 > Black Tank Dump Valve
CarnationSailor
Cathedral City, CA
Posted: 06/02/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
When I dump a full black tank, the valve opens very easy, no problem. I flush the tank for 5 to 10 minutes, then I close the valve for 5 minutes to let it partially fill. When I then pull the handle to open the valve again, it is so difficult that I almost cannot open it. Been this way for a couple of years, and now I thought I might do something about it.
I put tank valve lubricant in the tank periodically, but that doesn't seem to make any difference. Any ideas why full it is a piece of cake to open, and after flushing and partially filling, you almost need a gorilla to open it.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
CA Traveler
The Western States
Posted: 06/02/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Something in the seal dries out over time and then swells with usage? Regardless why not just replace the valve and be done with it?
2014 Grand Cherokee Overland
Bob
LadyRVer
Posted: 06/02/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Might try spraying handle/metal rod with silicone. Or probably just need to replace. I did my tank, took me about 3 hours.. but I got it done.
IAMICHABOD
Sunny So Cal
Posted: 06/02/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I found that lubricating it during a dump as in this video works.
I have used this method for many years to lubricate my valves and have had no problems with them at all.
This Video will show how to do it
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Durb
NW
Posted: 06/02/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do you turn off the water to the black tank rinse before opening the valve? Could be the incoming water is building pressure inside the tank and binding the valve.
Lynnmor
Red Lion
Posted: 06/03/21 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Good thought. The tank has a vent thru the roof and can only build pressure if that vent is blocked. What can happen is that the vent pipe slipped down into the tank and is now under water, or even worse, resting on the bottom.
jdc1
Rescue, Ca
Posted: 06/03/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Add liquid detergent to the tank occasionally.
CarnationSailor
Cathedral City, CA
Posted: 06/03/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
I think if this was happening, the vent pipe would also have to be mostly blocked, but not so much that normal usage builds pressure. I could test this by waiting 30 minutes or so after partially filling tank to give it time to bleed off. If it works easily after giving it time to bleed off, then I think this might prove your theory.
CarnationSailor
Cathedral City, CA
Posted: 06/03/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
If I recall correctly, the roof top vent cap is attached to the vent pipe with screws. So it seems unlikely that the pipe slipped down; however, if it did, then the vent cap should be missing. At any rate, I'll check out this possibility.
CarnationSailor
Cathedral City, CA
Posted: 06/03/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a good solution for sure - if your dump valves are exposed and easy to get to. I would have to either drop the coroplast or cut a hole in it, and I'm not ready to go there yet.
