RV.Net Open Roads Forum: 24 ft or less B+ with over head bed.
Open Roads Forum  >  Class C Motorhomes  >  B+
 > 24 ft or less B+ with over head bed.
Page of 5
Gjac
Milford, CT
Posted: 06/03/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
In looking on line I notice most B+ MH's eliminate the long overhang over the front cab and the Queen bed. They look more aero dynamic and have less overall height. Some claim they ride better than a C. The ones I looked at have an entertainment center and you lose the overhead storage and bed. What models if any come with a single bed over head and not the entertainment center? Also do any of the B+ models come with a large storage area in the rear like many of the C's have?
theoldwizard1
SE MI
Posted: 06/03/21 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
No overcab bed is the biggest difference between a B+ and a C.
rlw999
Washington State
Posted: 06/03/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
To get that nice aerodynamic look that you like, the overcab area is very shallow and narrow, not really enough for a comfortable bed, even single sized... you'd never be able to sit up because of the angled portion. I've never seen one that tried to squeeze a bed in that area, but you could probably do something custom if you had a small person to put up there.
bobndot
Posted: 06/03/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
By the time you finish researching these rvs , you will have to start over with class D and class E models. [emoticon]
If you need extra sleeping in a smaller rv ........
See the Dynamax 24RB models. Other mfgs might offer the same floorplan.
Its not a cabover bed for one but a QB for 2. Plus a sofa and dinette which both can made into a sleeper.
Ed_Gee
Central Oregon coast
Posted: 06/03/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
That is a fallacy. There is no such thing as a Class B+ Except in the minds of some marketing sales persons. Take the Dynamax Isata 3 for just one example...
No overhead cab bed, But clearly a Class C . There are many others, too. If its built on a Cut-A-Way chassis like the Sprinter or Ford Transit, its a Class C. If it is a modified van chassis, it is a Class B.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
ron.dittmer
North-East Illinois
Posted: 06/03/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
The Phoenix Cruiser has always been a B+. I own one with the typical cabinets and TV in that area. You could special order that space as a bunk. To get it so, you would sacrifice what I have plus the easy entry into the cab area. The overhead bunk would make an excellent loft for a child or pet to sleep in as well as for open bulk storage. It would also increase roll-over protection because the van roof with its rear support would not be cut.
Here is an old Phoenix Cruiser, maybe a 2002 model year, with the overhead bunk. I think today it would be finished off with more interior volume. If you sought an exceptionally deep bunk, I think you could have the factory build it some additional inches more rearward.
For comparison, here is my rig.
This is what is done to every PC like mine which is just about every one made. It is also what happens to every other class B+ and C motorhome.
* This post was edited 06/05/21 06:11am by ron.dittmer *
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
Gjac
Milford, CT
Posted: 06/04/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Your right Bob, trying to get all the important features you want in a small C is very daunting. The 24 RB is interesting, I have not seen that drop down queen in a Class C before. Too bad Dynamax doesn't make these anymore they were $69k brand new, on a Promaster chassis, the new ones on the Mercedes Chassis are $165K.
Gjac
Milford, CT
Posted: 06/04/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I don't watch TV when I camp or travel so the storage to me is more important. I guess the real question is do B+ MH's that are usually lower height ride any better than a Class C with the overhang in front, assuming the same length and WB? Lower height, lower CG, one piece FG cap, rear FG cap would be the main benefits I see. Also as Ron pointed out the cutaway roof would be important to get in and out off the front seat. If the ride quality is the same I think the outside and inside storage, more FW and a lower price would be a good trade off. Am I missing anything?
klutchdust
Orange, California
Posted: 06/04/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Having owned a Itasca Cambria for 6 years I know this. The front aerodynamic nose will not support a human sleeping in it, it is a fiberglass nose cone, that's it. It bobbed up and down when traveling and had no structural framing or support. I would not store anything up there. It contained some wiring for the audio and entertainment systems. The TV was mounted to a cheesy aluminum frame , speakers to each side. As far as "does it handle differently". I was not pleased with the handling of that coach, a 31 footer, , until I installed new shocks and had the front end aligned. it came with Roadmaster sway bars front and rear. The new shocks alone took out the pounding when even railroad tracks were crossed. Highly recommend spending $$$ for shocks. Good shocks will cost you , worth it though.
DrewE
Vermont
Posted: 06/04/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I don't have personal experience to compare with, but ride quality should be fairly similar if they're based on the same base chassis. Most of the weight of a motorhome is towards the floor; the CG difference between a normal class C and a "class B+" is not that great, and the overall height is also not all that different as it's mainly determined by the height of a human plus the floor height, neither of which change a great deal between the two styles. The somewhat improved aerodynamics probably would contribute to a bit better cruising at highway speed (better acceleration when passing, etc.). Likewise, if a little less tall overall, they logically should do a bit better with crosswinds and not getting pushed around by passing semis.
Overall ride quality will be influenced much more by the chassis used, the length, wheelbase, weight, and balance of the finished vehicle, the suspension setup and tuning and improvements (if any), etc. Since most B+ styles are more towards the upper end of motorhomes in price and furnishing and so forth, it's not unreasonable to expect that they've paid due attention to these sorts of things, which may not always be expected to be the case as much for more budget class C's. Expectations and reality are, of course, not necessarily exactly the same.
Page of 5
